Why a steel bonnet
Re: Why a steel bonnet
Post by kiwi »
Thread Bear wrote:It does not matter.
My interest was related to the 1.9 oiler as they seem to have steel bonnets where as the 1.7 oiler has plastic. Yet the 1.9 has a smaller fuel tank than the 1.7, which suggests a sensitivity to all up weight. The steel bonnet feels a lot heavier so I would prefer a larger fuel tank, please.
Is the N/A 1.9 noiser than the 1.7 turbo version. I am tempted to say it is.
Maybe Citroen expected the 1.7 to be driven a lot harder than I drive it. Sort of 1.9 for better off peasants and 1.7 for Parisians to belt down the peage to the country pad for the weekend.
Really? As far as I was aware the 1.9 has a 66 litre tank as it has the extra 14 litre expansion tank sitting in the wheel arch? I could be wrong but after getting 60 litres in the TXD once I dont think so.
1990 BX19 TZS Auto 06/11/1989
Not sure about the TXD, but the RD certainly doesn't have the extra tank.
My 14 had a bigger tank than many thought it should, and I remember the adverts from the like of Audi in the 90's making a big thing about how far theircars would go on a tank of fuel (without actually saying how much fuel it used!) so maybe Citroen fitted the extra tank to more models later on in production in order to make the fuel range more competitive.
Post by Mothman »
My TGS has a 52 litre tank. Made in 1990, i believe the whole range went over to a 66 litre tank from 1991. Some models such as valvers had it straight away. All my MK1s have the 52 ltr tank.
I think all the range started with 52lt except the 14's which from memory were around 46lt - they had certainly switched to 53lt by 1990.
What you have to remember is that these are French cars built by French people. Trying to apply logic to discern the why's and wherefore's of their construction - consequently - is a fools errand.
The answer to the question, 'why has my TGD got a metal bonnet' is 'why not?' I'm happy with that. :D
Paul296 wrote:Trying to apply logic to discern the why's and wherefore's of their construction - consequently - is a fools errand.
Yet it is curious that even where it is known that a conclusion cannot be reached, people like to debate these issues ad infinitum judging from this thread and the ones that have gone before on the same subject. :wink:
bx petrol auto saloon
My TXi has a steel bonnet =D>
Vince,
47,594 Miles from new.
Owned for 3 years sorned.
69,000 Miles from new.
Owned for 15 years T & T.
Post by kiwi »
BX14 44 litre MK1
BX16 52 litre Mk1
BX19GT 52 Litre
BX19GTI 66 litre
BX19TZS 66 Litre
BX19TRS 66 Litre
BXTXD 66 Litre
Those just the models I have owned and observed and yes have records for :)
Then I found one the many glovebox owners guides and
BXTE/BX14TGE 44 litres
BX16 TGE/TGS/TZS Saloon and Estate 52 litres
BX19 TRS?TZi/TZS/GTI/16 Valve/ BX 4x4 all 66 litres
BX17TGD/19TGD 52 litres
BX19TZD/TGD Turbo/TZD Turbo plus estate 66 litres
That should put the fuel tank debate to bed
Sort of, anyway - my 14TGE had a 52 ltr tank, but that may have been fitted at a later date!
Getting back to the noise question, i believe the n/a is noisier, not because of the bonnet, the gearing is lower so its revving more at the same speed as a TD & because there is a turbo, that acts as a silencer so it is quieter because of that.
Stinkwheel
Post by Stinkwheel »
Do you think i could get one of these in steel?
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
Post by kiwi »
MULLEY wrote:Getting back to the noise question, i believe the n/a is noisier, not because of the bonnet, the gearing is lower so its revving more at the same speed as a TD & because there is a turbo, that acts as a silencer so it is quieter because of that.
Metal bonnet and plastic bonnet have the same sound proofing material pad installed, so I doubt its to do with noise.
Stinkwheel
And just to be a contrary bar-steward and keep this fairly pointless and unanswerable thread going............
My 93 TZD estate has a Composite. My 93 1.6i TXi has a steel one.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Thread Bear
Post by Thread Bear »
Stinkwheel wrote:Do you think i could get one of these in steel?
In Holland maybe, so you can clog it with impunity.
Is that a 10 gallon hat or just the 9, sir? Suit you, ooh!
The TXD has a different one to my TZD, but then again you've got to make some room for the intercooler on one of them ;)
