Rear Arm bearings.
Re: Rear Arm bearings.
well Mr wheel
are you going to share the secret of were/who you bought them from
- Stinkwheel
indeed malcolm.......
e - bay item number 281108074769. The seller was car_parts_universe. And they were listed as Citroen Xantia rear suspension arm repair kits.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- DavidRutherford
- BX Digit man!
Now comes the fun bit...
Have you done these before? There are a couple of pointers that will save much swearing.
65 Peugeot Boxer work van 280k - x 136
ebay link please..i'll take some @ that.
- Stinkwheel
I have David, but not for a good few years, so any 'tips' greatly appreciated.DavidRutherford wrote:Now comes the fun bit...
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
It looks like they only had the ONE PAIRrutter123 wrote:ebay link pleaMse..i'll take some @ that.
Is this link any good @ £62.18 a pair (£31.09 a side) not much less than the /\ price though ?rutter123 wrote:got mine from camberley auto factors 2 kits £70 skf too. tho not a stock item they got them in for me at cost + 20%.
BX Bandit wrote:Jay had the actual bearing part number. If the rest is ok you could save a few pounds by buying the bearings only. Either pm him mate or search on here, Jay is good at documenting such info.
No need to wait for Jay chapsmat_fenwick wrote:I did just that, so i'll try and dig out the part number if Jay doesn't see this. Cost was around a tenner for the two bearings, but I had to buy the seal from GSF as I didn't have reliable dimensions I could search for. I.e. the old seal was knackered. It was £4 posted I think for a couple of seals though, so certainly a cheaper way to do the job.
As it was me, that initially posted up the bearing number TIMKEN JL22349F, heres another thread which may be of use Bearing X REF. !
EDIT:- Just found a 'Timken JL22349F' on E-bay with Free postage for only £5.90 !
Click on diagram for link
However ! I note that the listing states another bearing option/number "JL22349F/JL22310" so thats another possibility to look out for ?Specifications for this item Brand Name Timken, Mfr Part # JL22349F
Main dimensions:
d mm?inch .. D mm?inch .. T mm?inch B mm?inch ass kg?lb ?
22.003/0.8663
D mm?inch
41.000/1.6142
T mm?inch
14.500/0.5709
B mm?inch
14.500/0.5709
Mass kg?lb ?
0.078/0.172
OE bearing price and part No. for two bearings ( a bit steep ) from citroen
75472408 ARM BEARING 21.51 GBP 25.81 GBP 51.62 GBP
fits all these models on doing an all family search on service citroen
1 document(s) found for C5 II
4 document(s) found for C15
1 document(s) found for BX
1 document(s) found for XANTIA
1 document(s) found for XM II
1 document(s) found for XANTIA II
arm seals and spacer bush's for one arm from citroen
0000513320 BEARING BUSH 2.32 GBP 2.78 GBP 5.56 GBP
0000515414 SUSP ARM SEAL 3.24 GBP 3.89 GBP 7.78 GBP
spacer/pivot tube each
0000513252 SUSPENSN SPACER 7.83 GBP 9.40 GBP 9.40 GBP
Spotted on E-bay/GSF SEALS £4.49 each and BEARINGS £12 each + £2.95 postage on top (for either items) which is strange as most of GSF's E-bay listing were with Free deliverymat_fenwick wrote:I did just that, so i'll try and dig out the pat number if Jay doesn't see this. Cost was around a tenner for the two bearings, but I had to buy the seal from GSF as I didn't have reliable dimensions I could search for. I.e. the old seal was knackered. It was £4 posted I think for a couple of seals though, so certainly a cheaper way to do the job.
Therefore the bearing (From Lithuania) still far cheaper @ £5.90 inclusive of delivery and a 'Timken' brand too !
This recent E-BAY listing for a pair sold for £60+£6 for postage !
So if any one missed them and are looking for a single unit or pair heres some more, BUT be AWARE you'll need a pair of bearings to make a Complete kit up !
The Rear Radius arm repair 'Spindle kit' (Excluding the Taper Roller Bearings) are £14.99 with free postage !
+ A pair (For one-side) of the 'Timken JL22349F' on E-bay with Free postage for only £5.90 x 2 = £11.80 !
Click on images for links
So summing up the /\ option that's £26.79 per side or £53.58 for a pair which is very reasonable IMHO !
As you can see very limited number of the 'Spindle kits' available !
Good luck if you secure them !
yes but will the seller of these bearings ship free to the UK from LithuaniaRxBX wrote: + A pair (For one-side) of the 'Timken JL22349F' on E-bay with Free postage for only £5.90 x 2 = £11.80 !
According to the sellers listing YES, for Standard 'Royal Mail' Delivery (Click onto the 'Postage and Packing Tab')citronut wrote:.............
