The transpennine transplant.
sleepy0905
Post by sleepy0905 »
Thats the thing that puzzles me as it will only do 85 flat out but i was wondering if it could be sucking air on the fuel side but i am going to check the pipe connections but it was one of those airbrain ideas.
Keeper of the site Goat
Post by cavmad »
Aaron, I got 90mph out of the estate quite regulary and I`m pretty sure I had it to near a ton one day (off road, of course!).
Vauxhall apologist.
Post by ken newbold »
Different size wheels, maybe?
sleepy0905
Good point ken i am running the 16v wheels with the 6j rims and 195 60 14 tyres but i wouldnt of thought that would of made that much difference as the other Engine and box were ok with them so i am looking for ideas, as billy said he had no problems so i am wondering if it is an adjustment thing or air in fuel or something along those lines.
Just a quick idea if we got the timing belt a tooth out or something would that make a difference.
Yes it would, a big difference, you'd have known about it already.
The only other thing that comes to mind is, the timing belt will be tight now, once it's had time to stretch, that could make a difference.
Post by cavmad »
It could well make a difference in that the speedo could be out due to different sized tyres. Quite a common phenomenom, usually though where 14" wheels are replaced by 17" wheels for example.
Stick some standard wheels back on and take it for a good blast, see if the speedo magically climbs back up to what I know it should!
Vauxhall apologist.
sleepy0905
I am going to check the belt and timing tomorrow and just make sure I will keep you posted. :?
I know the engine and box is fine as billy was breezing round the uk in it so it is going to be something stupid like an adjustment or something I am still eternally gratefull though as my poor old engine was on its last legs so I work on the theory that i dont do that much motorway work and it is running very sweet so i am happy and i will just poddle on checking the adjustments.
Good idea, it's easy enough to do, but I doubt you be achiving 85 mph if it were a tooth out.
BTW, how fast do you want to go. :lol:
Sleepy - 195.60 X 14 tyre has a circumfrence of 1844 mm and a 165.70 x 14 has a circumfrence of 1848mm - so I would have thought that the difference was well below the accuracy of calibration of the speedo - let alone be of any significance! (about 0.2%)
I would have thought that had the timing been 1 tooth out it would have been noticeable - showing one or more of the usual diesel complaints - slow, smokey, noisy, quiet, difficult to start.
I'm slightly surprised that you quote the maximum revs available as being 4300 as I always thought a N/A diesel would rev a little higher - 4600? - the 4300 limit is certainly true for a TD.
85 flat out in 5th is a bit slow - I'd have expected 100 or so - ie running out of power before revs in 5th gear. However all may not be lost - apparently its easy to change the 5th gears by removing the end cover with the gearbox in situ. After a bit of research it may be that a set of TD 5th gears would improve things - albeit probably giving you a set of sprint gears for 1-4 and an overdrive 5th. (N/A diesel approx 23 mph per 100 in 5th - TD approx 26. - if you're interested I'll work it out properly)
sleepy0905
well apart from the top speed of 85 i have had a bit of a difficult and lumpy cold start but as i said to ken i was thinking glow plugs as it is ok after it is started and been running for about 10 seconds.
I agree with you over th cold start - I was thinking of clouds of smoke and great reluctance to do anything rather than something that clears after 10 seconds. What did the gearbox come from - If I know I may be able to find some ratios
Rev counter calibration wouldn't be affected by gear ratios - and I'm not even going to dare suggest that you wouldn't notice the difference between 85 and 100!
sleepy0905
The engine and box came out of cavmads old 92 bx TGD estate.
but as cavmad has said it was fine and infact he thinks he has had it to a ton but definately to 90 i am working on the lines of an ajustment as it was straight out and into mine the only thing that was done was the belt and clutch.
Sleepy - the plot thickens:
My 1989 Glass technical specifications book states that different final drives were used on saloons and estates for N/A diesels. This was with the BE 1 gearbox - which interestingly had the number BN43 for the saloon and BN44 for the estate.
The ratios quoted are saloon 3.94:1 and estate 4.0625:1. (incidentally the saloon one is the same as haynes quote for the ZX 1.9D). The rest of the ratios are0.757; 0.969; 1.250; 1.850; 3.250; R3.333:1
I'll try and translate this into something more meaningful - oh life was simple with straight through top gears!
If my arithmetic is correct the MPH per 1000 rpm figures are (195.60x14 tyres)
saloon - 23.04 (what I was expecting)
estate - 22.356. (seems about right)
However using the estate figure I'd expect 4300rpm to be 96 MPH - which would be good for a BX 1.9D I would have thought. Citroen quote a calculated max of 103 for a BX 19 D and 100 for the same estate. What Car for 1990 quote a top speed of 98 (tested not supplied) for the saloon.
sleepy0905
I think its all down to ajustment so i will have to check the belt timing and the throttle adjustment as they are the only things desturbed in the transplant apart from the obvious water and diesel pipes.
