Very Sloppy Gearchange
- Tim Leech
- x 148
Re: Very Sloppy Gearchange
Ordered from our very unhelpful local stealer...apparently coming from France so will take a while..
- Tim Leech
- x 148
I removed the gearknob, gaiter and innter gaiter yesterday to have a quick look at the linkage/selector on the Estate....amazingly most of the bushes have gone and its so rusty, there a good inch of free playon the shaft where the bushes once were!.
So Im hoping it may be an easy fix with a couple of bushes and washers!
ooooh la la
are you allowed to use nob, shaft, inch and free play in the same thread young Timmy
ps.
missed one
you also used bush, well i never
missed one
- Tim Leech
- x 148
Once, along time ago, never again....citronut wrote:ps.
missed one
Can I do this from inside the car (dismantle the linkage/selector) as I have borrowed a selection of rubber bushes and washers from work I want to try and "pack it out with" and tighten up the change.
My GT spat it's linkage bushes a while bak. So I removed the rubber and metal bush entirely
As Sloppy as it is now, I have gotten used to it =-- and I have no problems finding any gears..previously it would struggle to sometimes find first or reverse..So message to you ...all or nothing ..either replace the linkage bush or remove it entirely.
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
- Tim Leech
- x 148
Now sorted, very fiddly, but 2 2p sized washers had sorted most of the slack, although theres play further down the linkages, but thats to be expected with 204000 miles!
- citsncycles
204k - Pah, that's nothing!
- Tim Leech
- x 148
I know Mike, its barely.....although it is on the original engine, gearbox and possibly even clutch!!!
- citsncycles
Beat me on the engine stakes then! Not sure about the gearbox, although I do plan on swapping it for a diesel hatchback box I have.
