All good now, took it for a run up the bypass today after winding out the mixture screw on the airflow meter a few turns, now idles steady at 900rpm takes a few secs to settle down, starts nice when cold, i suspect the dizzy timing is slightly out as there is a little hesitation at low rpm before it bursts into life, will strobe the timing when the gun arrives hopefully tmrw, booked in for re-test sat morn.
quite lively the gti's aren't they?
erratic idle again gti 8v
65 Peugeot Boxer work van 280k - x 136
Re: erratic idle again gti 8v
- MULLEY
Glad you've got it sorted, nothing worse than trying to fault find without success. I always found my Gti 8valve quite torqey & went very well when pushing on
