HAS A MOT TILL MAY 3OTH 2104
Actually not that far from me and a little bit tempting at £675 with the MOT on the BX very soon and likely to have corrosion issues.
Welcome to the world of the pile of POO - C5'sMULLEY wrote:I've had to have the following done, at approx 116400 odd miles:
Driver side balljoint & droplink
4x Dunlop Sport Bluresponse
Psgr front inner door handle replaced with 2nd hand item off the bay of dread.
Grinding sound at the rear is the inner wheel catching the rear brake calliper, so looks like the wrong wheels have been fitted, now that is fucking annoying, anyway, solution was to grind away 1mm off the calliper so that i now clears it. I do have 2 spare steel wheels that came with the car, i'll get them to check whether these are the correct size & if so i'll get them swapped over.
Passed MOT with one advisory, slight leak on exhaust, unfortunately its near to the cat, hopefully it can be welded as otherwise its a cat replacement, erm no taSo far, this car has cost me a lot of money over the purchase price, so not that impressed, i think the seller must have known all this stuff was coming up.
It does seem to drive very well now, but i suspect that it won't be long before the electric hydraulic pump packs in along with those exepnsive silver spheres which must still be the originals, oh the joy's of buying cheap old cars, aaaargh!!!
Still got to sort out some internal trim bits, stereo has a mind of its own, i tried to find the pollen filter, no luck there, perhaps this one doesn't have one fitted?
Some water is getting into the car, not sure where from, any ideas?
Still need to get the car lexia'd to see what horrors are thrown up. A few screws & bolts missing from the engine bay need sourcing etc....
Initial impressions of the new tyres are, they are very quiet compared to what was on before, so thats a positive
Hi Mark,bxzx16v wrote:What's wrong RxBx, no xantia love? Bad experience with one?.
Mark
I know where there's an early 1.9TD VSX that needs a home!I have been tempted by a Xant a few times but never quite made the step. It would have to be the 1.9 TD for me.
