Autobox oil dipstick: Where can i find?
Slagtrooper
Re: Autobox oil dipstick: Where can i find?
Post by Slagtrooper »
My box doesn't engage reverse gear. That's my main big problem :lol:
I think i'ts better trying the basics, checking the oil level and changing the old, 2,5 L that can be dropped.
I have like, 10% of hope that reverse gear isn't broken - Changing oil and washing the filter being enough for fixing it.
Citroën BX GTi 1993
. XU9JAZ engine, ZF 4HP14 Automatic gearbox
. Leather Seats, Air Conditioner, electric mirrors, windows and sunroof
. "16V type" Speedline Rims, "Ducktail" spoiler and rear vents
ORGA 5219 (February 22, 1991) - Made in Uruguay
Hot steamy night alone, I wait for you ♫ Cold brittle morning alone and I cry for you ♪ And when you finally call ♫ You cloak your moves in the shadows ♪♫♪
Post by Mothman »
Thats interesting to know. I didnt realise there was a filter in the gearbox. How do you get at it?
BMW X1
Auto's have strainer filters on the oil pick up inside the actual gearbox sump, removal of the sump pan is required.
Post by Mothman »
Cheers Kevan,
didnt know that.
Slagtrooper
So, if i buy a standard dipstick, cut to make it stay with 48 cm of lenght, grind marks representing the little spheres of the old one...It could work? Thinking every day about it
Citroën BX GTi 1993
Slagtrooper
Gary C wrote:Dipstick from BX16TRS auto with 171c engine.
Overall length being similar, the question is whether the dip length to the first ball is the same and spacing to second. If so, a bit of welding rod or similar could be used to check oil levels.
Sorry, Gary C, i did not understand this part: "whether the dip length to the first ball is the same and spacing to second."
Is about the distance between the balls or the end of the stick to center of the second ball? I'm confused...
Anyway, i will try a cheap stick about 47 cm and make markings as says the first and second ball measures, counting as the balls have 2 mm radius
If someone have a better idea, please reply :)
Citroën BX GTi 1993
Slagtrooper
Last week i were talking with demag about my problem and he sent lovely images for me.
When i make the dipstick, i will post photos here. Thank you again, demag!
Citroën BX GTi 1993
