Broken Bx
Re: Broken Bx
You will be glad to here that I am the new owner of this, so it'll be floating about on here again. Would love to learn any history on the car.
1985 CITROEN BX 19GT C1TBX
Re: Broken Bx
Hi alex
Welcome aboard, Chris Abbott bought the car some years ago with very low miles and added the spoiler, GTI interior, wheels etc, it was written off earlier this year when the bottom ball joint failed and the car needed a driveshaft aswell a few bits and bobs but was basically a sound car.
The speedo cable was broken, they are available new from Chevronics and I know he mentioned the stiff steering when cold which I think may be a FDV.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
Re: Broken Bx
Cheers Tim. I was wondering about the interior, it is the most comfortable one I've ever had. Even more than my electric BBS racing seats.Tim Leech wrote:Hi alex
I've yet to isolate the noise, so could be driveshaft related.
Awesome cheers, I'll get that on order. Unless a 1.4 petrol would have the same cable, as I have one spare.
FDV? I'm not familiar with that abbreviation.
Re: Broken Bx
The top cables are all the same, its the lower part that is different and one from a 1.4 wont fit as its a different gearbox.
The driveshaft could have been damaged in the accident (although I imagine it may have been changed?, as could the wheel bearing etc.
BX 16v seats are amazingly comfortable (which is what was fitted)
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- x 12
Re: Broken Bx
FDV = Flow Diverter (or Distributer?) Valve. You'll find it on the front of the engine near to the accumulator sphere. It's a black roughly square thing with 5? rigid pipes coming out of it. It splits the high pressure fluid from the pump to the steering and suspension/brakes. It has tiny plastic filters in it that over time can become clogged, causing heavy steering. It also has little plugs on it that have a tendency to start leaking LHM once the rubber seals perish.
Repair kits are available.
Heavy steering from cold could also be a sign of a tired pump finding it harder to move the LHM around while it's cold and viscous.
1991 Citroen BX 16v
- x 27
Re: Broken Bx
Yep stiff steering is often a worn pump or just (if you are lucky) blocked filters in the reservoir.
Sent from a computer using the app my brain.
The Joy of BX with just one Citroën to my name now. Will I sing Bye Bye to my GTI or will it be Till death us do part.
Re: Broken Bx
I would stick some hydraflush in it, and clean the filters out, failing that look for a new pump, which is surprising given the low miles.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
Re: Broken Bx
RobC wrote:FDV = Flow Diverter (or Distributer?) Valve. You'll find it on the front of the engine near to the accumulator sphere. It's a black roughly square thing with 5? rigid pipes coming out of it. It splits the high pressure fluid from the pump to the steering and suspension/brakes. It has tiny plastic filters in it that over time can become clogged, causing heavy steering. It also has little plugs on it that have a tendency to start leaking LHM once the rubber seals perish.
Cheers! I'll do some investigation, is it just a take it off and have a look job?
Do you have a link to such a repair kit?
Jaba wrote:Yep stiff steering is often a worn pump or just (if you are lucky) blocked filters in the reservoir.
I will try to go through the entire hydraulic system if I get the chance, do a flush and filters and all that.Tim Leech wrote:I would stick some hydraflush in it, and clean the filters out, failing that look for a new pump, which is surprising given the low miles.
The second BX I bought, for parts. Allegedly has a good pump so I'll swap that over if I need to.
- x 12
Re: Broken Bx
In a nutshell, no. Once you take it off (which will be a lot of faff) you then need to dismantle it v e r y carefully before you can do any investigation, and putting it back together is quite an intricate process.alexrossmartin wrote:RobC wrote:FDV = Flow Diverter (or Distributer?) Valve. You'll find it on the front of the engine near to the accumulator sphere. It's a black roughly square thing with 5? rigid pipes coming out of it. It splits the high pressure fluid from the pump to the steering and suspension/brakes. It has tiny plastic filters in it that over time can become clogged, causing heavy steering. It also has little plugs on it that have a tendency to start leaking LHM once the rubber seals perish.
I'd go down the hydraflush route first.
Here's a good description of the job. http://citroen.tramontana.co.hu/suspens ... istributor
Beware that pumps vary between models so unless you've bought exactly the same model you may not be able to swop them over. IIRC There are at least 4 different types, maybe more!
1991 Citroen BX 16v
Re: Broken Bx
[/quote]
Beware that pumps vary between models so unless you've bought exactly the same model you may not be able to swop them over. IIRC There are at least 4 different types, maybe more![/quote]
Ah right. Where's the best place to buy hydraflush then?
I can see why the complexity of the suspension puts people off these cars!
I didn't realise that, I'm sure mine won't fit, seeing as it came from a 1.4 petrol then.
- x 12
Re: Broken Bx
The suspension's not really that complex at all. But poor maintenance of the hydraulics (i.e never cleaning the filters and/or changing the LHM, which unfortunately is commonplace) leads to premature wear on components such as these. I'll stick my neck out and say that if every BX had had its filters and LHM looked after properly right from the start of its life then you'd get at least 200k miles before any hydraulic issues arose - other than flat spheres of course.
hydraflush: http://www.gsfcarparts.com/980pc0130
NB if you order by midnight tonight and use code WOW35 then you'll get a whopping 35% discount.
1991 Citroen BX 16v
Re: Broken Bx
I'm sure once I actually get under the bonnet and look ill understand it much better. But until then, it's difficult to get my head round!RobC wrote:The suspension's not really that complex at all. But poor maintenance of the hydraulics (i.e never cleaning the filters and/or changing the LHM, which unfortunately is commonplace) leads to premature wear on components such as these. I'll stick my neck out and say that if every BX had had its filters and LHM looked after properly right from the start of its life then you'd get at least 200k miles before any hydraulic issues arose - other than flat spheres of course.
Well hopefully once I've caught up with maintenance, it should be trouble free.
I did see it on GSF, but I thought that the £45 price tag was a little high. A 35% will sort that right out though!
Re: Broken Bx
Afaik the pumps on petrol and diesel are different?
On a petrol they run of the same belt as the alternator ie the bottom pulley
On the diesel they run from a camshaft driven pulley.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- x 6
Re: Broken Bx
I'd say 150k+ or 13 years personally, having had two high pressure pipes rot through. One on the 1.4 a galvanised one and last year on a 23 year old 1.6 with (the better) black anti corrosion finish. However you are correct, if the system is drained, cleaned and refilled every 35k and the spheres changed, the system gives very little trouble. Had a couple of rear ride height correctors go (one failed, the other became 'sticky'), but having done 280k+ in BXs' thats a pretty good record. Almost certainly would have had to replace several shock absorbers and other associated stuff on other cars, at probably more expense and harder to do. Also don't forget the 'old rubber' issue of front return pipes, Octopus etc.RobC wrote:The suspension's not really that complex at all. But poor maintenance of the hydraulics (i.e never cleaning the filters and/or changing the LHM, which unfortunately is commonplace) leads to premature wear on components such as these. I'll stick my neck out and say that if every BX had had its filters and LHM looked after properly right from the start of its life then you'd get at least 200k miles before any hydraulic issues arose - other than flat spheres of course.
Actually Tim the hydraulic belt is separate to the alternator one on the petrols, just comes off the same centre at the bottom. Of course you then get into 4 V or 6 V, ie no a/c or with a/c etc....
Re: Broken Bx
Can I say more modern Merc front bottom ball joints, Borrowed rubbish design on VW vans, too. The ball joint is on the wrong way round and pulls out. Many a Merc has had a boss eyed moment, all hushed up off course, never happens, old boy! To add to this buffoonery the design went from a simple £20 swap to a very expensive new wishbone assembly, with just as useless ball joint welded into it. Modern cars, total rubbish!Tinkley wrote:Never seen a Morris - Minor, Marina etc with kingpin failure......MULLEY wrote:It's only a simple mechanical failure, fair enough it may have shook me up a bit at the time, but i'd have gotten the car fixed, but heyho, it looks like it could make the seller a tidy sum. g.they used to be common. Seen a couple of very modern ones (cars and vans) let go the steering joint on mini r/abouts locally so hardly a BX major weakness. Might be the cumulative damge from the shitty potholes, so worth inspecting a little more frequently.
