It's a long shot but........
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
sleepy0905 wrote:I am going tomorrow to get this pulley for you Mr B
Top Man!
1991 Landrover Discovery
1995 VW Golf SE
sleepy0905
Post by sleepy0905 »
sorry Mr B but it has already gone. :cry:
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
Oh well never mind, I'll have to make one from an old cam belt tensioner. Thanks for looking, you're a Gent. 8)
1995 VW Golf SE
sleepy0905
No problem i was going for some bits anyway sorry i couldnt help.
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
Sorted! I've modified a timing belt tensioner, shortened, drilled fitted. Jobs a good'n :wink:
1995 VW Golf SE
AlanS
Post by AlanS »
I take it you had to drill the hole on the mounting plate to swap over and then re-weld the pin back in after the tensioner had been fitted?
Any chance of a bit of detail for future reference??
Alan S
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
I'll take a picture and post it later :wink:
1995 VW Golf SE
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
Here's the promised pictures. The tensioner pulley is a modified XUD diesel timing belt tensioner.
I've also fitted another pulley to increase the contact area on the 90a/h alternator. It's the bit in between the U shaped hose, it's from an XM and fits on the alternator mounting bolt.
1995 VW Golf SE
AlanS
Post by AlanS »
That second pulley looks the goods as regards getting the belt area contact.
A word to the wise as regards the cars (16Vs anyway) with air/con that might help you guys over there who have it, is to back off the alternator adjustment and sit the belt into position. Adjust the tensioner up to near its maximum tension setting and then adjust the belt via the alternator adjustment. This pulls the belt about another 10 - 15 degrees around the compressor and crankshaft pulleys and helps prevent the horrible high pitched squeal that comes from them when the air/con is turned on when the car is red hot inside and on a hot day. Once they slip a couple of times, this slip tends then to become a common occurrence on start up regardless of how the belt is adjusted and eventually results in another new belt.
Alan S
AlanS
Post by AlanS »
For future reference, would these guys be a starter to be able to supply something like this?
http://62.110.184.188/dayco/en/products-tensioners.htm
Alan S
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
Had a peek at Vannys car yesterday and I could have used a lower tensioner
from a A/C Xantia as this bolts onto the 3 bolt holes on a alloy sump :roll:
1995 VW Golf SE
