Replacing front/back LHM pipes - how much time does it take?
andycadabra
Re: Replacing front/back LHM pipes - how much time does it take?
Post by andycadabra »
Thanks for those ideas, but I had to order it on Wednesday, and they don't take returns. He did mention it was the only part of its kind which is still supplied, so the Xantia brake pipe solution might be good for the other pipe which has a coil next to this one. it is 4.5 mm by the way
1992 BX 17TZD 130k
1987 BX 16TRS SORN
KevR
Post by KevR »
It's easy enough to make those pipes if you have the flaring tool - I invested in the heavy duty one as I have various Cits which use the same kind of pipes. Or Pleiades will presumably be able to do it for you.
