Full set of good Speedlines (grey, 6j)
djoptix
Re: Full set of good Speedlines (grey, 6j)
Post by djoptix »
^ that all sounds like a good idea... Dalhousie, sure I can't interest you in a swap...?
Dalhousie2008
Post by Dalhousie2008 »
Gren wrote:Car was set up to handle neutrally in the dry. You need the wider tyres on the front to get rid of the standard set up understeer. This car slides beautifully on all 4 in the dry in the current configuration and will make the first bend at Goodwood at 100mph, about 15mph better than the standard set up!
Check the clearance on the big brakes on the front. Not sure you'll get them under the standard wheels!
Thanks for the info gren
Dalhousie2008
djoptix wrote:^ that all sounds like a good idea... Dalhousie, sure I can't interest you in a swap...?
Just sent you a pm but I've managed to find a set of original wheels now.
