BX 19GT PROBLEM NO MORE!
- x 59
Re: BX 19GT PROBLEMS
Can't say I'm surprised Tim, it's going to be carb related. Still, least it's new now!
1983 16TRS (Sunrise red) - 1987 GTi 16v (Black) - 1989 16 Valve (Venetian red) - 1990 16 Valve (Venetian red)
1985 CITROEN BX 19GT C1TBX
2003 ROVER 25 1.6 iXL AW03EEA
2005 MG ZTT CDTi PLUS + - x 114
Carb rebuilt and fitted, new ignition amp, coil and rotor arm also fitted and it's no different.
Dizzy cap ordered.
Intermittent weak spark noticed when warm and plug out.
It's getting fuel, air and the timings fine so must be ignition?
Next stop is a new dizzy?
Dizzy cap ordered.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- x 59
Unless there's more to this than I know, I genuinely can't think of anything else on that car that could cause the issue, other than the carb. Will it rev up while the auto-choke is in operation?
stupid double post
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
Yes, but today it reved up ok and ran for a while and was well up to temp and would respond to throttle input, then just died, and refused to restart, until it cooled, it restarted briefly but was popping and misfiring and then stopped again.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- x 59
Doesn't make sense that it's anything ignition-related then, other than the amp. Are you certain the carb is ok? Who rebuilt it?
Got your text by the way, I do have a spare dizzy from a 1600. No idea how well it works, but assume they're the same as the 1900?
The guy who rebuilt it a an ex Peugeot mechanic and the head of a local technical college and is rebuilding a CX.
He said asides a bit of dirt the carb was in good order.
Mines running a ducellier dizzy.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- x 59
Did he strip the auto-choke unit? Or just the carb itself?
The dizzy just wouldn't behave like this if it failed. It would either work all the time, or play up all the time. It wouldn't be more likely to work when the autochoke is closed as it has no way of knowing what the carb is doing.
The auto choke had been off for a while when it died?
The plugs are wet and you can smell petrol though.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- x 6
Fuel vaporisation?
- x 59
Video doesn't work
Weak and strong spark sounds like electrical. Im not that familiar with the petrol bx. But how does it pick up when to spark? Im guessing camshaft driven dizzy? Check the amplifier and all wiring. Have a double check of any wires that are none replacable as part of the ignition circuit. Incorrect coils do this kind of thing on the triumphs i work on.
2001 Peugeot 206 2.0 Hdi
1999 Peugeot Expert Van
1993 Citroen BX 1.9TXD
1992 Citroen BX 1.9TXD
1980 Triumph TR8
1972 Triumph Stag
1967 Triumph GT6
1980 Triumph TR8
1972 Triumph Stag
1967 Triumph GT6
- x 59
Don't bother taking the plugs out to test them, get some plug testers or a timing gun, and test them while they're fitted. It's much harder for a plug to spark under compression than it is in the atmosphere, so you might find it's barely sparking at all. Dizzy doesn't generate the spark, it just distributes it, but then you've changed the things that generate the spark already, so it may be a wiring issue.
What still makes no sense at all, is why it'll run on cold-start fine, but only stop running once the choke opens again, and as soon as you touch the throttle pedal. Unless something's getting lost in translation here, or not getting conveyed over 'tinternet very well, I can't see how it's electrical.
Vid doesn't work for me, so can't give an opinion on the spark, but like I say, I'd test them fitted rather than in the open, as that's not the most accurate method in the world!
- x 6
Actually the dizzy does 'know' what the carb is doing a bit, from the vacuum advance/retard pipe. However it may be that the initial spark from the dizzy itself is too low causing too low a voltage at the coil and ultimately plugs. It happens on outboards and motorcycles where the stator (primary ignition winding coils) breaks down with marginal heat.....
Worth checking your battery voltage is good and alternator output high enough.
I'm afraid I don't trust HT leads to last much more than 12-15k although they can be good for 50k. My old 1.4 taught me that, new leads every plug change or they would break down a few k later. First thing was slightly worse fuel consumption, then the odd miss, then rough running and bad starting. Caps I change religiously every 25-35k max along with arms. They just get too pitted for accurate sparking and fuel economy. I've not had a cracked one yet on a BX, but some pretty badly pitted contacts and corossion, including in the lead end socket.
Copper leads and NGK caps last longer by a mile than the carbon filled common leads btw.
As it happens I am in process of sorting a 2001 Mariner 25Hp with similar problems and the main suspects are stator and float needle and valve. Either can give similar symptoms. Been through pretty much all the rest, coil packs, replaced waxstat, stripped and cleaned carb (Keihan) including the 0.2mm or 0.15 holes in it... etc etc.
