1991 Citroën bx 1.9 tdg breaking
65 Peugeot Boxer work van 280k - x 121
Re: 1991 Citroën bx 1.9 tdg breaking
loftus hall i have a good flow valve here if you need one, off the car good working order £25 + £3 postage can send asap.
Sounds good, just sent a private message.
Not sure if pm got to you,
What's best way to pay you? Pay Pal?
all received.
- My Cars: Citroen Dispatch 2.0L HDi 2005
Fiat Panda 4x4 Sisley 1991 - x 6
... does it have a good cam shaft?
- JohnDragonMan
Drives: Citroen Dispatch with retrofitted air conditioning
always buy base spec. that way you have the fun of putting all the cool bit on your vehicle
- My Cars: VW T4 Caravelle 2.5tdi (Current)
Citroen bx 1.9 d (For sale)
Citroen bx 16rs Break (Sold) - x 2
Hi Michael
Curious if you can help.
Where my estate parcel shelf pivots as the trail gate opens the near side or passenger side hinge has sheared off.
Any chance you can help here?
Thanks
Thanks
^^ the plastics on mine have snapped on the drivers side causing the parcel shelf to drop
- JohnDragonMan
- x 11
Hello, Would you have the front seat belts with the stalks
in good clean condition for mot pass.
Thanks
Alan
Thanks
Alan
- x 11
Hello, Do u have the front seat belts set including
the 2 stalks that are clean for my mot.
Thanks
Thanks
- My Cars: Citroen BX 16 TGS
Saab 900 S
Porsche 911 Carrera 2
BX 16 TRS in 1996 (F343 HDS)
Hi, I need both screen wash reservoirs for my TGS. Do you happen to know if they're the same size and connections? My car is a H Reg thanks
Firebladesteve i have a good pair of front/rear screenwash reservoirs with good pumps and caps if you need them, they are nice and clean with no muck inside £23 pair inc post. All mk2's are the same.
Saab 900 S
Thanks for that. As long as they're not cracked and leaking like my current ones then that's fine!
I've PM'd you...
I've PM'd you...
They are fine no cracks no leaks all good, no pm received.
Saab 900 S
Didn't realise I had to press submit, review it, then press submit again! Anyway, done now..
- My Cars: 1992 BX19TGD ESTATE 178k
2014 Fiat Ducato Sportivo - x 1
If parts are still available from this car I need the passenger side front window seal. The one that pushes into the door and goes all the way around the window.
If you have this please let me know.
Thanks
Thanks
