Hi everybody. The rear height corrector is leaking. Oil drips down at the side of one of the membranes. I wanted to replace the membrane, but couldn´t open the screw. It turns loose, together with the brass cover. I tried to hold the cover with pliers, didn´t work. Any idea how to loosen the screw without destroying something? Thanks a lot for help! So many leakages, patience is slowly running out...
Peter
Rear height corrector leaking
marrowpe
- My Cars: CItroen BX TRD Break
petermorrisminor
- My Cars: There will always be a BX unless they BX rated. Citroen BX 14 st tropez
Re: Rear height corrector leaking
PLease see my input of 19 oct. 18 and 6 nov. re this. it could simply be a short lenght of rubber hose you be needing.
