Hi Mark yes I have some rear arms , the castings are good but most likely will need a rebuild on the bearings and seals etc, the new one I listed has been sold, or I can rebuild your arms if they are usable or rebuild a pair I have here, plenty of options let me know
Rear arm
- My Cars: 65 Peugeot Boxer van 160k
Nissan Micra K13 the wife's run around - x 74
Re: Rear arm
- x 6
Re: Rear arm
Hi cliff, i'm in need of an osr, non abs arm suitable for rebuild. The one on my txd which is still in use is too far gone and one i had on a spare subframe is also too far gone.
Barry
Barry
1993 tzd estate, on sorn
1991 4x4 estate, on the road
Re: Rear arm
Hi Barry, I should have a few I will let you know Friday.
- x 6
Re: Rear arm
i've managed to sort this out now, i had to build an arm up with weld and get it back to size with a die grinder and flap discs.
thanks anyway.
thanks anyway.
Re: Rear arm
barry badger wrote: ↑Wed Jul 25, 2018 12:01 ami've managed to sort this out now, i had to build an arm up with weld and get it back to size with a die grinder and flap discs.
thanks anyway.
Been there, done that
Re: Rear arm
That's what bx ownership is all about.
