Hi All
On my 1991 16v, I've swapped a heater tap for a replacement, when it was out of the car, it was moving fine, fully opening and closing. Installed the tap, and connected it up to the control panel heater control and I can only turn the knob from cold to half way hot, also the tap isn't fully closing because it's reaching the stopper on the back of the control panel, so it's always blowing out warm air.
Is there any way to adjust the heater tap opening/closing, so that it closes and opens fully?
I've checked the length of the new and old cable and they are the same, there are two holes on the back of the heater control to insert the metal wire through and I've put it into the same hole the old one came out of. It's starting to drive me a bit nuts now and I don't want to have to take the tap out again if there is some way to adjust it!
Thanks for any help.
Brian
Heater Tap Adjustment
- My Cars: BX 16 Valve
- My Cars: 65 Peugeot Boxer van 160k
Nissan Micra K13 the wife's run around - x 75
Re: Heater Tap Adjustment
I don't think there is any adjustment as such, isn't there a few small clips that hold the control cable in place on both the heater control panel and the heater housing? If the cable is clipped on in the wrong position you will compromise movement at the tap end,.
Jaba may be the man for this one.
- My Cars: BX 16v Ph2
- x 20
The adjustment nut is hopefully shown in the picture below. The nut the cable goes in to crimps down onto the cable to adjust the total travel.
Thanks guys, having had a bit more time to play, part of the reason it wasn't moving as much as it should is that the sound insulation has dropped off the bulk head and was blocking the tap from moving fully.
It's still not perfect, the cables are clipped properly and the cable itself is in the right place on the tap, so not sure what's going on, but it's now fully closing and opening most of the way, so I'm happy enough with it.
Thanks for the advice.
