Well saved
venetian red can and does polish up well, ive done it myself a few times.
Factory electric sunroof too which was an option!
1987 BX 16RS (RED)
1985 CITROEN BX 19GT C1TBX
Re: 1987 BX 16RS (RED)
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- My Cars: 65 Peugeot Boxer van 160k
Nissan Micra K13 the wife's run around - x 74
Would strongly advise you change the cambelt before you attempt to drive it any distance, the one on it will be perished after standing for several years. Don't risk it and trash your engine it's not worth it for £20, I would certainly do a full fluids change as well.
- My Cars: 88 Citroen BX 16RS
95 Peugeot 405 Dturbo Executive
89 Mazda MX5
94 Subaru MV - x 4
Thanks for the positive words guys, I'm really happy with it. If I hadn't taken it then the scrapman was coming to pick it up, and I couldn't let that happen, it's far too good.
Yes, i've seen some photos of someone doing this, brings it back up a treat! It will definitely be getting this, though as you say, it's not a top priority, bigger fish to fry first.jamescarruthers wrote: ↑Mon Jan 28, 2019 10:37 amI'm sure this if quite far down your list but just letting you know that the rear bumper can be refreshed using a heat gun. Just give it a good scrub/wash, wave a heat gun over it and voila! I then kept it topped up with Autoglym bumper and tyre gel. My red one looked amazing!
That's good to hear about it polishing up well, I've had mixed experiences with polishing faded red cars in the past, never seem to keep their colour for long afterwards. I hope that isn't the case with this one. I honestly wish it was an option they hadn't chosen, I haven't dared open it yet as the amount of rust on the edges inside does not bode well!
Don't worry, it'll be getting a thorough going over mechanically before any significant running occurs! Starting with the starter motor, as the solonoid keeps jamming badly!rutter123 wrote: ↑Mon Jan 28, 2019 8:53 pmWould strongly advise you change the cambelt before you attempt to drive it any distance, the one on it will be perished after standing for several years. Don't risk it and trash your engine it's not worth it for £20, I would certainly do a full fluids change as well.
88 Citroen BX 16RS
89 Mazda MX5
94 Subaru MV
89 Mazda MX5
94 Subaru MV
The sunroofs leak because the drain tubes get blocked, plenty of information on here on how to unblock them.
As for the faded paint, it will cut back but as you say will fade again, the trick is to keep it well polished (I found TCUT red polish to help).
viewtopic.php?f=13&t=7399&start=30
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
And of course Ven Red is the best colour, or in my case 50 shades of red.
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
ZX Volcane keeping others going - x 15
Once polished, Autoglym Super Resin Polish is good on Venetian red (it may not have enough cut for the first polish). Keep up with it and it an you can maintain the shine without removing too many microns as you could with some products. Top off with a good lsp. Halfords have a deal on AG HD wax.
https://www.halfords.com/webapp/wcs/sto ... reId=10001
- x 57
That is a satisfying outcome
1983 16TRS (Sunrise red) - 1987 GTi 16v (Black) - 1989 16 Valve (Venetian red) - 1990 16 Valve (Venetian red)
