'87 19 RD with optional extra grime
- My Cars: 2001 BMW 330Ci Convertible
1993 Citroen BX TZD Turbo
2015 Audi A5 Black Edition Coupe
Re: '87 19 RD with optional extra grime
Don't you think it's time to give the people a update?
65 Peugeot Boxer work van 280k - x 111
Snap. Mine has the same rust issue both sides. Unfortunately THE WORST place for quite common rust, there is no easy way to fix it properly.
Sadly the demise of many bx, as once discovered it's generally terminal once it spreads to the inner sills and chassis rails, repairable? Yes, cost effective, prob not as it's pretty much a rear end strip out and other bits Will almost certainly need replacing along the way.
