What did you do with your BX today ?
65 Peugeot Boxer work van 280k - x 110
Re: What did you do with your BX today ?
I just looked at mine today still up on blocks of wood, and all sorts of junk slowly being piled up on the roof and bonnet and dust so thick you can barely see thru the windows, I shook my head, switched the lights off and shut the garage door.
Still, the spiders seem quite at home inside the car.
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
ZX Volcane keeping others going - x 22
Just had a quick sit inside and turned on the Atlanta SQR 47 to have a quick blast of Menswear Nuisance, sounds so much better in cassette.
Previously ipace/discovery 5/velar and many others including 2 bx gti back in early 1990 - x 11
I hear the love of cassette
My current blue point player has no power.
Hope to fix it, or replace like for like. With a hidden Bluetooth unit for my phone.
ToDo list.
1. ̶G̶e̶t̶ ̶c̶a̶m̶ ̶b̶e̶t̶ ̶e̶t̶c̶ ̶r̶e̶p̶l̶a̶c̶e̶d̶ ̶e̶t̶c̶
Have a GnT
2. G̶e̶t̶ ̶t̶h̶e̶ ̶r̶a̶d̶i̶o̶ ̶t̶o̶ ̶w̶o̶r̶k̶.̶ ̶
Have a GnT
3. Adjust the clutch
Have a GnT
Have a GnT
Have a GnT
6. Replace rear spheres
Have a GnT
7. Replace bottom hose
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
I cleared all the crap off mine, Inc 1 r/c aeroplane, 3 old pictures. 1 old printer, 3 sets of car mats, a sledge, some underlay and the parcel shelf.
Lots of new scratches as well.
- x 12
Are you... me?
Wait, no you're not mine is still under a mountain of things.
1989 Citroën BX 16v
1993 Citroën BX 16v project
Removed the broken windscreen spray bar and installed the Mercedes screen wash block.
Much improved screen clean.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
- My Cars: LOTS!
- x 123
Had the DTR for a run to derby to see a mate for a socially distanced Tea and meet his new puppy.
Still need to replace the O/S rack gaiter.....
- LHD, NA, AC, RP_5800
Left it getting a 'rinse' in the steady rain.
Tomorrow morning: Covid jab #1
, and collect the A/C O-rings* from Citroen.
* Junta torica in Spanish. Isn't that nice?
Fixed the blue point radio - power disconnected !!
Wiped down with some LHM. The front struts inside the gator. Apparently this stops the juddering when going up or down. Worked a treat.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
I momentarily had visions there of the poor old radio getting the LHM treatment
Some regular road use and a few Citrobics should keep the front struts creak-free, as they will be self-lubricating.
BX today just rested. Rain stopped, now 22°C and sunny.
Friday productive: Pfizer jab, and lots of O-rings.
Hell, I always swore I'd never go anywhere near F*c*b**k.
This thread has a lot to answer for.
It’s had plenty of citrobics whilst parked up. . The manual lube defiantly helped the radio !!.
Am not driving it at the moment. As I am unsure of cam belt history. Hoping to catch up with Kitch soon as he is replacing my cam belt etc.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
- My Cars: BX GTi, C3 Auto
- x 46
I charged the battery, cleared out the boot and fitted a small wooden trim, sprayed black, to stop the parcel shelf from trying to descend into the boot space. Checked the oil and water. I still need to have a look underneath before I challenge the local garage with an MOT.
Cut and shaped 6 pieces of steel sheet ready for welding the o/s sill, chassis rail and axle mounting.
- x 28
Drove 400 miles to SW England and back. Smiles all round!
1991 Citroen BX 16v
Booked in for a cam belt, pump and tensioner replacement. Plus a quick once over the auto choke etc
Can wait to be able to drive it whenever I like when the belt is changed.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
