What did you do with your BX today ?
- Our Trim Guru
2020s - A shinier red TZD estate has replaced scruffy 19TXD "Red Shed". - x 10
Re: What did you do with your BX today ?
Finally able to use the BX after nearly 2 weeks of immobility. Diesel without queues seems to have reached my part of the South coast, for at least the time being. Now for MOT stuff...
Put a cover over it.
- My Cars: Citroen BX14 RE
Nissan Micra Shape - x 31
I drove home yesterday and broke the passenger mirror mechanism so I'll fit the spare I have. I also changed the fuel filter and the emulsion tube in the carburettor.
- x 91
I've still just been driving it! Probably going to SORN it at the end of the month though, to avoid the salt. Rain I don't mind, stonechips and wear & tear I can deal with, but I hate rust!
- LHD, NA, AC, RP_5800
A thorough waxing (cavities and underside) prevents rust. It really does. Even in the UK!
I got the message back in the 80's, and nothing has rusted since. Not one jot.
To make the job really easy, if you have access to a compressor, a Sealey SG18 is great to use, and does a thorough job.
Will work with any of the liquid cavity waxes.
. It pressurises the reservoir, where standard paint spray guns don't.
- x 91
Oh I'm sure it does, I could cake it in Dinitrol but in the interests of preserving it I'll just stow it and use the C6 for the winter.white exec wrote: Sun Oct 17, 2021 5:14 pm A thorough waxing (cavities and underside) prevents rust. It really does. Even in the UK!
A very silly thing, yesterday.
Managed to scrape the rear r.h. door against our metal driveway gate, when leaving in a hurry and having to negotiate a delivery truck trying to park outside.
Green paint wiped off with petrol and Mer. Am hoping the large dimple might push out.
The rubbing strip took the brunt.
Tw*t.
Tw*t.
- x 49
Oh no, so easily done!
Sorted a slightly annoying hydraulic leak.
Ever since getting the car (a year ago now) there has been the odd green drip hanging from the pressure regulator. So slow, didn't do anything about it, except check all the unions and return hose for tightness.
Last weekend, we went out to lunch with some neighbour friends, and gave them their first ride in the BX; suitably impressed. Leaving their property involved putting the suspension on Int.High for less than a minute, to get over some drainage humps in the narrow road. When taking a full-lock corner, was surprised to get Brake-STOP dash lights flickering on briefly, which promptly disappeared.
Low fluid level, as I found out next day when observing a rapid drip (one every 3-4 secs) from the steering output union on the regulator underside, whenever the engine was running. The union was not at all tight, and its rubber sleeve (not a genuine green-striped one) was in bad shape. The 6.35mm steel pipe was also slightly curved where it went through the union, and might not have been engaging properly with the centre drilling.
Anyhow, pipe strightened, a new seal improvised from a short length of rubber tubing, and the union refitted - going in much further than before, which is a good sign.
Have got a decent stock of 3.5mm union seals, but no 4.5 or 6.35mm ones. Should be some here (from Citroen) tomorrow, so will re-do the joint with the pukka bit. Over a litre of LHM needed to be thrown in to get the level right again, but everything now dry at the front end. Someone had been there before...
- My Cars: Citroen Acadiane
Citroen BX 16 TGS
The moderns.
Skoda Superb
Citroen C1
The Motor Bike,
250 MZ - x 12
Another small win. Fed up with the front wiper missing a large part in the middle of the windscreen, I set about rectifying this. This involved bending the wiper blade and lubricating the pivots. It’s nice to be able to see properly. Over the next few weekends, I need to adjust the tails gate catch, work out why the heat controls are not opening the correct flaps, and replace the dash board lamps. Not looking forward to that job.
- x 91
Well, it wasn't today - in fact, it was weeks ago - but here's the most recent thing I did on my mk1:
https://youtu.be/6Js2GG5Qlvg
- My Cars: BX GTi, C3 Auto
- x 103
Fixed the wobbly RH headlight. The slotted plastic retainer had somehow partially snapped of so I found a replacement in a spare headlight and snapped that in to secure it firmly in place.
And I booked it in to have the rust in the top corners of the windscreen sorted out in a couple of months time.
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
ZX Volcane keeping others going - x 69
Started it, let it run a while, did a few Citrobics.
198x Citroen BX16 TRS auto
1991 Saab 900 16v convertible
2007 Lexus RX 400h SE - x 156
Cleaned mine, checked the wheel nut torque (height of excitement
2006 Lexus RX 400h SE hybrid
'88 BX GTi (a long time ago) - x 144
Polished and waxed it to death. Off to bed now for a six o'clock start
