What did you do with your BX today ?
white exec
My Cars: 1992 BX19D Millesime
- LHD, NA, AC, RP_5800
1996 XM 2.5TD Exclusive
x 70
Re: What did you do with your BX today ?
Post by white exec »
Dave_16v wrote: Mon May 24, 2021 3:04 pm
Pcheaven wrote: Mon May 24, 2021 2:40 pm Discovered my rear tyres are 20 years old. :)
Check your spare then, it might be the original.
Discovered (last year) that mine was! #-o
Pcheaven
My Cars: Landrover discovery sport 2020
Previously ipace/discovery 5/velar and many others including 2 bx gti back in early 1990
x 12
Post by Pcheaven »
Top tip
Cheers. Can’t believe I forgot that
If it is then one of the existing front tyres can go on it ( they are approx 4 yes old with plenty of tread)
ToDo list.
Have a GnT
Have a GnT
3. Adjust the clutch
Have a GnT
Have a GnT
Have a GnT
6. Replace rear spheres
Have a GnT
7. Replace bottom hose
x 135
I washed my 3 and the xantia, plus others at the "barn"
deltic
x 45
Post by deltic »
Wished mine happy 30th birthday today!
frog
x 12
Post by frog »
Not quite today but my BX made it to the local cars and coffee last weekend
1989 Citroën BX 16v
1993 Citroën BX 16v project
white exec
x 70
Wow, gosh \:D/
Pcheaven
x 12
Post by Pcheaven »
frog wrote: Mon May 24, 2021 11:57 pm Not quite today but my BX made it to the local cars and coffee last weekend
Great wheels.
Could do with something nicer on my bx ??
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
x 40
Post by Dave_16v »
Car of the day. For some reason, I like that a lot. 😊
Fumbler
My Cars: Citroen BX14 RE
Nissan Micra Shape
x 31
Post by Fumbler »
Re-aligned the wiper yesterday. All is good.
My Cars: BX GTi, C3 Auto
x 71
Started to do the prelims for replacing a front to rear hydraulic pipe from the HC to the priority valve. As its such a fiddly job and I like to put the replacements in all the pipe clips along the route I started wondering why am I actually doing this. I put it on my things to do list in 2016 and could not remember why.
So I had a long search to find the rusty bit and eventually discovered it just forward of the rear wheel. It was surface rust that I had covered up in 2016 with the black stuff. But it was still only surface rust not serious so I decided to inhibit the rust and underseal it again and thereby deferring it again for another 5 years unless I need to take the LH suspension arm off.
Then having taken the middle silencer off for access most of its guts spilled out when I upended it. As the front silencer has rusted away internally too I have ended up replacing the exhaust system instead of a hydraulic pipe.
Going for a long walk tomorrow and a pub lunch to get me away from my needy BX.
white exec
x 70
Big pipe, little pipe - all in a day's work! Hope the pub lunch goes well. \:D/
Surprising how durable the hydraulic lines are, unless they happen to be kept wrapped in muddy dampness (eg in subframe gaps).
I'd entirely forgotten just how basic a diesel exhaust system was on the BX - no front end box at all. Diesel exhausts tend not to rust, and so they can get forgotten about. Do find the 19D exhaust a tad "chuffy" at the back at idle . . . am used to dead silence on the XM.
A turbo quietens exhaust enormously, by smoothing out the shock-waves. Have driven our RAV4 D4D with nothing except 0.5m of downpipe attached: surprisingly quiet, except at full throttle.
Did wonder about fitting a front-end box to the 19D, to quieten things down a bit. Good idea? Any other options?
deltic
x 45
Post by deltic »
And a Lancia Fulvia Zagato on the right!
white exec
x 70
And on the subject of Zagato, try this for a one-off...
The wheel trims are the giveaway.
x 71
Yes Lancia made some great cars. I had a Beta for about 3 years, not one of their great ones but an enjoyable car nevertheless.
I could not beat its rust however so sold the 4 year old car for peanuts to a guy who wanted the engine.
x 136
Post by rutter123 »
Those trims are very similar to Rover P6 2000
