Aviation fluid (red oil) was around before LHM, it has lower viscosity and MilSpec for example, now has a higher VI than LHM and it meets a lot of the system requirements, OK with seals, corrosion, non foaming etc. It could be used to flush a system in that it's thinner.
I am not recommending it, it's up to everyone to research themselves with anything like like this unless it is an established method. I think reasonably regular changes and filter cleaning negates the need but with some cars having numerous owners, you really don't know their history and flushing might beneficial.
Hydraurincage wanted
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
ZX Volcane keeping others going - x 69
Re: Hydraurincage wanted
- x 174
I find just changing the LHM, and cleaning the filters out worked ok, if the car is performing as it should then I wouldn't bother flushing
- LHD, NA, AC, RP_5800
Where the H'cage came in was when the system was extremely dirty, due to lack of previous LHM changes.
It was particularly good as washing off internal black deposits.
MSDS listed it as essentially LHM, but with added cleaning aromatics.
