JOB LOT
BOB6844
JOB LOT
Post by BOB6844 »
I have some parts for sale now that my BX days are over.
Headlamp - Valeo 480443 - used - V.G.C.
Headlamp - Valeo 480444 - used - V.G.C.
Front Sidelight - Signal Vision 10790 - used - small chip at bottom corner
Suspension Sphere - Drivelink 55113 - remanufactured/unused - V.G.C.
Wing Mirror - marked 1197 3130 - used - V.G.C.
Wing Mirror - marked 1197 3140 - used - V.G.C.
ABS Controller - ATE 91 537 75980 - used - condtion unknown
Suspension Pipes, all from Pleiades, all unused and in original packaging:
NBXP1 - Rear suspension 4-way union to Brake Valve
NBXP2 - Return pipe from rear Height Corrector
NBXP3 - Rear Height Corrector to Priority Valve
NBXP4 - feed to rear brakes, non-ABS
NBXP5 - rear O/S Brake Caliper feed
NBXP6 - rear N/S Brake Caliper feed
NBXP7 - O/S rear suspension feed
NBXP8 - N/S rear suspension feed
NBXP9 - rear Height Corrector to 4-way union
Alternator - Valeo A13N 181 - reconditioned - V.G.C.
Car Cover for BX - Monsoon CCC132 - used - V.G.C.
Timing Belt - Unipart GTB1049XS - unused - old stock
V-Ribbed Belt - Dayco 4PK954 - unused - old stock
V-Ribbed Belt - Dayco 10A0800C - unused - old stock
Cable - Bell Autoparts BHC2244 - unused - length 150cm; unable to identify use or vehicle
Cable - No I.D. - unused - length 132cm; unable to identify use or vehicle
Accumulator sphere and valve - valve marked "160" and "40" - used - unable to identify use or vehicle
Offered as a job lot at £200 collected from Up Holland, Lancashire.
More information gladly supplied on request. Apologies for the unknowns, all of which came to me without I.D.
