west bay valver
greendale65
west bay valver
Post by greendale65 »
Hi all,
Hope you are all ok
Can you help my valver has been parked up since before Christmas last
taxed it 1st April took her out for a run it stops problem it got her going
and it stoped again no spark got home via the AA
any idea next what to check next.
Re: west bay valver
Coil pack, ignition amplifier?
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
x 81
Re: west bay valver
Post by Dave_16v »
Depending on where the car has stood, I wonder if anything has collected moisture causing an intermittent issue, distributor cap for example. Something to check or at least tap or disconnect and reconnect are the relays located near the strut top on the o/s wing. Can't remember which does what off hand but I know they can cause starting issues. Crank sensor maybe another culprit as well as the ignition module.
greendale65
Re: west bay valver
Hi All.
Thanks for for your help
i'm going down the road your saying it did start and run but needs the
throttle then ease of throtttle then it stops so i have found a garage
near me knows a bit about these citroens hope i can get car to them
in two weeks time as the garage is moving to new site.
Hopefully it will sorted
for my 84
birthday next month
8) 8) 8)
