Hmmm, think I found the cause of the misfire.....
Ian_Fearn
Post by Ian_Fearn »
no.
Anybody got another set of injectors i could try?
Over and out from me
x 74
Mike P: The first one I used was an Intermotor cheapy shitty thing.....won't be using that again.
The second one was a Beru setup I got from work, looks much more solid and the metal terminals and much thicker.
Ian: If they use the same as the 16v, I have loads of known working ones. Shame I don't live closer to you.....I got quite good at sorting out bad running. My 16v used to cut out everytime I came to a junction, then everytime it was cold, then everytime you tried to start it, then everytime there was a weekend in the month.
Got it all sorted now though, its just persistance!
Ian_Fearn
Post by Ian_Fearn »
What were the causes of your issues?
I think the 16v ones are different. Got a picture of one i could look at?
x 74
Air flow meter mixture setting
TPS
CAS
Idle valve
And then all the plugs....had to go over all the pins one by one to make them fit tightly!
Its a process of elimination.
x 74
Ah, according to my sources your's should use the same injectors.
Ian_Fearn wrote:no.
Believe me! I had your problem & it got worse. Cleaning & testing on the custom machine will give you a tickover with a rock-steady needle on your rev counter. ( I was present in the workshop for the service of my injectors, that's why I am sure, seeing the before, during & after on the test never mind the absolute benefits when reinstalled on the car!)
Ian_Fearn
Post by Ian_Fearn »
Do you have a list of the part numbers then for my car??? Or even a supplier with reasonable prices, i'm prepared to chuck money at it to get it right!
I'm not aware mine even has a CAS, its the model with the earlier style Jetronic injection.
Want to flog some injectors???
x 74
Lol.....I have a list of every single part number for every single part for your car lol.
Not sure about the CAS on yours? If its Jetronic then I take most of that back.
Hows the FPR?
Ian_Fearn
Post by Ian_Fearn »
What is an FPR?
x 74
Fuel pressure regulator
Ian_Fearn
Post by Ian_Fearn »
Interesting idea there, i'd not thought about that.
That could be a real possibility.....
Any idea where i can get one from??
Barnsley BXer
Post by Barnsley BXer »
I've a spare engine you could take the injectors off.It's been stood outside for about 6 years though.
1990 GTI 4x4
1992 TZD
Ian_Fearn
Post by Ian_Fearn »
Would they be available for Sunday??? :lol:
Barnsley BXer
I've never messed about with injectors,whats involved in taking them out?I'm on afternoons,am trying to get my car sorted for the MOT and doing CCC stuff so I haven't much spare time on my hands.If it's pretty quick and simple,they will be in my boot for Sunday :D
1990 GTI 4x4
1992 TZD
Ian_Fearn
Post by Ian_Fearn »
Yes, they're quick and easy to get off.
Once the 2 petrol pipes are removed from the injector rail and the couple of bolts are removed off the rail its just a case of tugging them out of the block.
They're quite tight in there so they just require a bit of wiggling around.
Would be great if you could get the rail with fuel pressure reg and injectors to me. You will be suitably rewarded for your efforts!
