This area has been welded at some stage, all seems solid enough but rust is peering through Is this a common place for rust, I've not seen it before, and is it a structural thing ala MOT failure?
Other items I need to tackle are 1x cv joint and 2x rear arm bearings
Is this an mot problem?
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
- Keeper of the site Goat
Problem is the welding heat has discoloured the paint on the outside which is probably not just surface but will try the T cut option anyway thanks.
The whole thing looks solid so I may just whack it myself and see
'94 XM 2.1TD Break
'94 XM 2.1TD Break
I usually take the whack it or poke with a screwdriver approach.
I.e. If i break it then i know it needs sorting, if i dont then MOT man should pass it
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
