Hot Cold Selector!!!
Adam
Post by Adam »
After repairing the sheared pin on the TGD, checking the clips and greasing the inner cable behind the steering column, I still have no hot/cold control and now to top it all the same problem has happened on the TZD. They both worked fine the first time I tried them, then, just didn't work.
Any ideas chaps before I rip them both apart to change the cables???? :x :x :shock: :x
Previously Owned
1988 19DTR
1991 17TZD
1987 19GTI (Dads)
1992 17DTR (Mums)
Currently
1991 19TGD
1991 TZD Turbo (Breaking)
"Graculus" 1990 TGD Turbo (Restoring)
tom
Citroen Sorceror
x 38
Post by tom »
Sounds to me like the heater control valve is not being operated. Try working it manually.
