An interesting comparison
- Citroen Sorceror
- x 3
Citroen BX TZD Turbo Estate: 90 BHP 1077Kg.
Ford Focus Diesel Estate: 90 BHP 1295Kg.
- x 24
Check this out:
http://www.worldofmotorsports.com/car/m ... ?makeID=54
gives lots of specs...
but I don't know if I'd trust some of them - especially, for example Visa GTi power output figures or indeed there's an AX 4x4 listed. Was there one?!
- x 80
Yeah there was an AX 4x4. Only abroad though.
The Focus' are surely more powerful now though? 90bhp these days is gutless for a modern 1.8 diesel.
1990(H) 16Valve (Rouge Furio)
The old TDdi is pretty much the same as fitted to he previous mondeo/escort is only 90bhp as its just a 1.8 diesel engine with a turbo and intercooler and direct injection on the later models. However from about 2002 onwards they introuduced the TDci which is the much cleverer and more powerful common rail diesel which produce 90/110/115/130bhp and 150bhp, available in 1.6/1.8 (focus) and 2.0/2.2 (mondeo/transit and Jaguar X type).
You could still buy a focus with the old td-di engines on the lesser models until last year when the all models were brought out and the engine was dropped in favour of a 1.6tdci (90bhp) althought the same power as the old 1.8 it was much cleaner and quieter.
- x 80
The 1.4 and 1.6's are
- Keeper of the site Goat
I think Mercedes started all this `common rail` technology didn`t they? Tim, this Sharan thing pulls like a train and is badged as TDI so assuming it`s 130BHP engine?
From Tom`s post it would appear that things have stagnated/gone backwards but don`t forget all the airbags, side impact bars and cup holders will add to the weight. Doesn`t say much for engine performance though: it`s one thing having `luxuries` and another when you haven`t got much of an engine to pull it round.
Vauxhall apologist.
- x 80
It'll be 110bhp if its a red Icavmad wrote:I think Mercedes started all this `common rail` technology didn`t they? Tim, this Sharan thing pulls like a train and is badged as TDI so assuming it`s 130BHP engine?
Weight of modern cars is getting to be a real problem - mainly caused I suggest by lazy engineering.
Want more strength - and the easy way is simply to increase the amount and gauge of metal used.
But - suppose you want to stop intrusions into the side of a vehicle - one way is to put a steel beam there - and the other is to use a strong wire and be ingenious about mounting it, so that it pulls on other parts of the structure.
The simple demonstration of excess weight is the BX and the ZX - a plain 1.9D weighing about the same as a TD BX estate - which is about 16 inches longer. A C4 weighs about another 250Kg for a big diesel engined one. a C1 weighs about 1 tonne - same as a BX saloon diesel!
So far this weight increase has been hidden by the advances in diesel engines - but they will tale off as the major improvement has been the huge increase (5 - 7 times) in injection pressures producing better atomisation - and the abandonment of the Ricardo Comet indirect engines (a design coming from the 40's at the latest) in favour of direct injection.
- Citroen Sorceror
- x 3
I tried to compare like with like. I have no idea of luggage capacity of the Ford, or its drag coefficient but the power to weight ratio is significantly worse. Depending upon the gearing, it will be either slow or thirsty compared to a BX, maybe both. I'll leave you to speculate on tyre life! Air bags weigh very little, certainly no more than the weight increase due to HP suspension.
Further bad news: Spillers, makers of Winalot have announced poor figures and may have to call in the retrievers.
And when combined with one of the worse engines ever made (Ford`s 2.5 V6 24V) I think it`s just asking for trouble.docchevron1472 wrote:You mean a ford mondeo in a shell suit surley?!?!?tim leech wrote: and Jaguar X type![]()
Chris G
Funny how the Focus (and their ilk) don`t seemed to have moved forward ref power per weight (and surely economy?), yet this big lump of plastic Sharan thing with the aerodynamics of a block of flats pulls like a train and does 53+mpg.
Vauxhall apologist.
