Ive got a TZD today
- MULLEY
- MULLEY
Er new problem has reared its head, it needed 3 attempts of the ignition switch to get the glow plug light to come on & then it started ok, does this signal new glowplugs? or something else? this is the 1st time its done that & it happened when i was coming home from work today (its in a dry basement garage at work).... hoping someone can shed some light, perhaps it was a one off????
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
The dash light should come on irrespective of the glowplug condition..It is more likely to be a dirty contact - probably on the connections to the blue glowplug relay box fitted in the engine bay by the front n/s wing. Clean the contacts up with some emery cloth or wet and dry and see hot it goes. If you take the relay box off (only one bolt) you may as well open it and clean the relay contacts aswell...
- MULLEY
- MULLEY
- ken newbold
- MULLEY
