Ive got a TZD today
Tim, i'm not chucking the one you gave me i'm just swapping them over as i have a cd player in the other car. If i was getting rid, then of course you could have it back, but i'm not, so sorry.
Anyone got a spare speedo?
Keeper of the site Goat
Post by cavmad »
I`ve got a set of GTI clocks mate, though Ian Fearn has first dibs on the temp guage.
Vauxhall apologist.
I assume that they will work on the TZD, i just need to replace the speedo one only as rev counter & rest of instruments in the binnacle work ok. PM me if you have one, for costs etc..
Terry Brooks
Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
Post by Terry Brooks »
Barnsley BXer wrote: Aye, good point mate. It does help a bit though as I have a couple of good `rally slagging` lanes I can use on way/way home from work which are magic when wet and even better when snowy.
Where-abouts :?: ..........are they local to me :?: :idea:
Tel.
Terry Brooks wrote: Where-abouts :?: ..........are they local to me :?: :idea:
Tel.
Sounds like the birth of a plan. 8) :D
tim leech
Post by tim leech »
You can take the speedo to bit mate and free of the trip meter.
cavmad wrote:I`ve got a set of GTI clocks mate, though Ian Fearn has first dibs on the temp guage.
A GTi speedo will be wildly inaccurate in a TD. The gearing is higher in the TD so a GTi clock would read low....
Chris G
Ian_Fearn
Post by Ian_Fearn »
I still want them mate!
Just being lazy. Any idea how much they'd cost to post?
Over and out from me
Post by cavmad »
I reckon postage will be about £8.00 Ian. Iirc Mulley isn`t too far from you, if I send the whole lot could you two meet up and take what you want for them?
Mulley, somewhere about I`m pretty sure I have some standard TGD (i.e non turbo) clocks, if you or anyone else knows if the speedo will suit your TZD please let me know.
Ian, if you pm me your address and postcode I`ll send the clocks out to you mate, most likely Saturday morning if that`s o.k?
Vauxhall apologist.
Post by cavmad »
Tel.
Between Ellesmere Port and Chester mate, there`s one corner which is usually covered in gravel and when you hit it just right you can slide it perfectly around the bend.
Get it wrong (i.e with a Cortina automatic in the frost) and it`s a trouser-browningly experience :lol:
Vauxhall apologist.
Ian_Fearn
Post by Ian_Fearn »
cavmad wrote:I reckon postage will be about £8.00 Ian. Iirc Mulley isn`t too far from you, if I send the whole lot could you two meet up and take what you want for them?
PM sent mate.
Cheers.
Tim, good suggestion but i want a working trip & this one is knackered so its going to have to be a replacment speedo (with working trip).
Cheers for the offer Cavmad, anyone know if the N/A speedo works correctly on the turbo model?
Fraid not mate. a N/A clock would read low. It would have to be a TD clock to be accurate. A N/A clock would be 10mph out unless you change the profile of the tyres.
Chris G
tim leech
Post by tim leech »
Mulley theres a complete txd turbo in th elocal scrappers here if ur realy stuck, but its done nearly 200000miles so maybe not!
Tim, if the speedo clock works (must have working trip) then i will have it please. Anychance you will be visiting the spares monster & able to do an extraction? oh! & how much?
Ta
