Hi
We have started getting a fluid leak under both front wheel arches. The suspension rise fine and the front struts aren't particularly jerky.
It takes about a fortnight for the fluid level to drop from normal to stop light flickering point.
I clean the fluid off and raised and lowered the car several times but couldn't see any fluid leak. It didn't build up until after a few days. I've checked the return pipes but they seem to be ok.
Before I replace them I would appreciate any thoughts on the matter.
Also is there an easy way of fitting the clips?!!
Many thanks
Front wheel arch LHM leakage
- ken newbold
Many thanks for the responses.
I don't think it is the security valve return as it is completely dry under middle of car. But I will double check just to be sure as I am assuming the problem is strut related (never assume anything in life!!!)
With regard to the pincers fixing the clip how do you get the hook end past the notch?
