hi tim,tim leech wrote:Heres a thought a mate of mine said maybe the timings slipped hence why it wont start even when theres fule poured straight into the air intake?
It did bounce quite hard when it span its wheels which could make it jump?????
honestly i wouldn't go with thinking its that! it is usually something alot more simple with these cars. the res=ason i spent over 2 months trying to fix mine was because i went round testing and changing all the big complicated parts. go to the scrappers buy a second hand coil and plug it into your car. its a very simple and easy to do test and only cost you 5 quid. if its not that then at least you now have a spare one. test the basic systems first then we will get more complicated. i did think my belt had slipped and the crank sensor was gone and the compression may be fecked and i was completely wrong because i was being fooled buy insufficient sparks. i even got a big bolt of leccy shock when i forgot to turn the ign off and picked up a plug that was earthing on the engine i was unlucky enough that the dizzy had stopped right on that contact. it fecking hurts.
ps if you need spare crank sensors etc for future testing there are 3 of your car in my local scrappers. i can pick up sensor etc for you if you cant.
cheers rossco
