I'm Getting a 16v Tomorrow!
If the engine is meant to run on 98 octane then it will set the advance appropriately. If it run on lower ocatane the knock sensor will function and the ECU will retatard the ignition so that the engine doesn't destroy itself.
However this isn't quite as good as it seems as there was a purpose in the engine running in the advanced state in the first place - namely better efficiency.
Somehow I doubt if the retardation is progressive - ie I doubt if the thing retards by one degree and listens to the knock sensor and stops there if its OK - my guess is it retards by enough so that it won't knock if its on the real cheap stuff - so the loss in efficiency is more than it really needs to be if the fuel is one less than it should be.
The next question is what doesn it need to persuade it to go back to its 'advance' setting. I've heard it said that they really need disconnecting from the battery to make them forget all the settings and re-calibrate from scratch for best results.
Incidentally fuel is not necessarily the same. Many years I had a Scirrocco GTi which ran well when I got it. I always filled it from the same pumps (Esso) and over a month it got rather poor - then I was caught short as it were away from home and filled it with something else - instant cure! - So I avoided Esso for the rest of the time I had it!
- x 26
Nope, I mean the oil filter - you have to get down and dirty on the floor and look up! It's on the cambelt side of the oil filter. The black thing next to the oil FILLER is the idle speed control valve, and all 16vs have that.BX Bandit wrote:Did you mean oil filler? Yep, there's a little thingy connected to inlet manifold and air inlet duct. So mines an M1.3 which means it doesn't mind which fuel its on? I must say tho' it does seem alot better on the v-max but it could be cos' its had a good run instead of standing around??is if you find a black sensor with 2 wires coming out of it screwed into the engine block right next to the oil filter - that's yer knock sensor and it only came with the M1.3.
Why do recon Vmax is crap docco? I think the local Texaco will do super unleaded (98 ron???) and I'll check Tesco - it's a big store so they probably do, although I'm not keen on lining their pockets any further truth be known - daylight bluddy robbery that lot!!
Need to focus on the TD cos its MOT tomorrow!!!!!
1991 Citroen BX 16v
- docchevron
Dont get me wrong mate, V Power runs well in my car too. However, it can attack the plastic bits in fuel lines / pumps in older cars. this is something I have been told by someone that knows, wont mention names but I trust his word on this.Mike E (uk) wrote:" I know V power is crap "
I disagree, my 16V runs very nicely on it. costimax seems OK too.
Not tried the 99 tesco type yet.
The Tesco's stuff seems bl**dy good to me and is very cheap! And earns me enough clubcard points for a serious spending spree at xmas time (booze of course!!).
Chris G
- MULLEY
The high performance diesel fuels available today are really designed for modern PD/HDI diesels, a relative of mine who drives an Audi A6 reckons that BP advanced diesel makes a noticeable difference, back in the old days (well the nineties) Shell super used to make them run well to the extent that I would always put some in any diesel car I was selling, for our old living fossils any improvements are doubtful, biodiesel makes them run smoothly and quietly but if used at 100% causes an ultimate loss of power, a mix of 30% bio appears to be a good compromise.
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
- MULLEY
valver
Bandit you will be pleased to know that the ecu info is not as comprehensive as stated earlier - some P2s have the ML4.1 and some of the 1.3s come without knock sensor.
The true test to see which ecu you have is to look at the ecu and count the number of rows of pins th eplug fits onto
2 rows - 4.1
3 rows - 1.3
It is adviseable to run your valver on the best petrol you can get as if oyu thrash it a lot oyu will damage the seats with poor quality petrol despite what the citroen spec may say - I have seen many vakve seats on these engines nad they do regress.
Luke
2 rows - 4.1
3 rows - 1.3
Luke
- docchevron
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
OK, Where is the ECU - under one of the front seats?
I did get down and dirty and had a look up (not my words...honest) and there was a plug (2 wires I think) just by the Halfrauds oil filter.
- docchevron
Engine ECU is under the drivers seat mate.
Unless it's a left hooker of course!
Having driven it I'm fairly sure your's is a right hooker so, er, my original point stands!
Time for beer
Chris G
Time for beer
Chris G
valver
Yes indeedy under the passenger seat is the ABS control unit.
I was working on an Austrian left hooker the other day and the units are not switched over just the seats.
Luke
P.S. No comments about hookers from the Austrain left thankyou
Luke
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
3 rows of pins...which confirms its an M1.3?? It's nice and warm in the car at the moment cos I've got a fan heater to try and drive off the old moisture - gonna take a week or so I would of thought Still, can't bear to have it all moist over winter now now stop it!!!!
ecu
Yep that's a 1.3 sounds like it is with knock sensor as well if oyu have the thingy on the front of th eblock
Sunroof drains are the usual culprit for damp interiors
Luke
Luke
