CV joint or driveshaft change.
tim leech
Post by tim leech »
Where is Lockwoods by the way?
Post by ken newbold »
Bradford.
tim leech
Post by tim leech »
Do they deliver? thats a bit too far for me, think I will try and source some locally.
Ian_Fearn
Post by Ian_Fearn »
Yes Malcolm often delivers personally in either his insterstallar mileage BX or C15.
Over and out from me
tim leech
Post by tim leech »
Kewl ok as soon as I "holding folding" again I will give him a ring and get a pair of driveshafts ordered
tim leech
Post by tim leech »
Have managed to source locally for £60 each vat however they have asked dow many the do the driveshaft have? (relucter ring I expect) 29 or 90? have no idea myself anyone got a clue?
Its a great deal more than 29 - so 90 is my guess. I think the 29's are for a Peugeot that uses a different form of ABS.
29 would mean an angle of 12.41 degrees between teeth - or if the diameter of the ring is 60mm - each tooth would be 6.5 mm wide. Same diameter with 90 teeth they would be 2.01 wide which sounds much more like it.
tim leech
Post by tim leech »
Thanks jeremy, I will have alook at the spare shaft Ihave and count them up, I take it they want the number of teeth on the abs ring not the amount of splines on the driveshaft!
tom
Citroen Sorceror
2024. TxD 1.9D estate. 'Wheelybin'
x 12
Post by tom »
It is 90 to confirm that.
tim leech
Post by tim leech »
Thanks Tom.
