TZD restoration.
tom
Citroen Sorceror
Post by tom »
Thanks Jeremy! That sounds like welcome news. I was sure that it would be possible and, bearing in mind that I'll want to flush the radiator this year, I had thought of taking it out for this work. A bit of hardboard to protect the condenser though, will certainly be in evidence!
Vive les UX.
Just thinking about it -- when I had the top mount off to do the cambelt the engine tipped back with some determination. Angled sump doesn't help but I don't think I could have pulled it forward if I had tried - so a bit of ingenuity may be needed.
tom
Citroen Sorceror
Post by tom »
Back in Borehamwooden after the usual run up the M3, I can report that the car has much improved smoothness although there is still much to do. I spent the afternoon cutting brass shim stock up to get the rear arms dead right so I'll be looking forward to that!
Vive les UX.
Oscar
Post by Oscar »
Funny thing, life.
I was saying to Stewart that I would like to start reconditioning various parts, and my starter engine packs up and gives me the opportunity to do just that.
On Saturday I was thinking that it would be worth doing a big recondition, and here Tom is doing exactly that.
I'm actually quite turned on at the thought of making the car better than new. Does that make me sad? a pervert? both?
Keep us updated Tom
Oscar
ellevie
Forum Treasurer
Post by ellevie »
tom wrote: Does anybody know BTW if strut bearings and seals can still be bought? .
slide bearing.....96 004 372.....£37.75
o-ring.............24 826 009.......£4.54
small kit...........95 597 221.......£3.44
big kit..............95 650 941......£20.07
This was back in September.
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
tom
Citroen Sorceror
Post by tom »
Thanks Ellevie. You are in my neck of the woods; did you use a local dealer?
Vive les UX.
ellevie
Forum Treasurer
Post by ellevie »
It was Freeborns. I didn't buy any of it, I just checked on price and availability. Only the small kit was in stock, the remainder would have had to be ordered in from central stores.
BX19TXD 150k K Reg
tom
Citroen Sorceror
Post by tom »
! They refuse point blank to supply anything for BXs these days which was why I asked.
Vive les UX.
ellevie
Forum Treasurer
Post by ellevie »
Yes, I had those part numbers already to hand before I contacted them. Otherwise they ask me for the car registration number and then they seem to come up against a brick wall. The last time I got something I supplied the number and it was ordered in but I had to pay for it up front. I think you should be ok if you ask them to check availability against the part numbers and then take it from there.
BX19TXD 150k K Reg
Wyatts in Winchester were always supposed to be more helpful. I've never used them myself but might be worth a try.
tom
Citroen Sorceror
Post by tom »
I have certainly found Wyatts helpful in the past and Yeoman's at Fareham seem to have a good attitude to older Citroens.
Vive les UX.
Martyn
Post by Martyn »
jeremy wrote:Just thinking about it -- when I had the top mount off to do the cambelt the engine tipped back with some determination. Angled sump doesn't help but I don't think I could have pulled it forward if I had tried - so a bit of ingenuity may be needed.
When I did my h/g I removed radiator, undid top mount after resting sump on a wooden block and used a spanish windlass round a bracket on head and the slam panel to pull engine forward. I could then "easily" get at manifolds! (I say I, but in truth my friend is an aircraft mechanic and I make the tea and hold things!) Martyn
1992 txd
1991 1.7 tzd
Stewart (oily!)
Post by Stewart (oily!) »
I did the same (spanish windlass)when I replaced my turbo, the doseur should be reasonably accessed that way, It might be worth disconnecting gearchange rods/exhaust to gain more angle.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
tom
Citroen Sorceror
Post by tom »
Well, ECP have let me down on the driveshaft:
2 weeks ago. We've got 'em. £35.
1 week ago. We need to do it on special order. 5 days, £58.
Yesterday. We can't get it.
One of their new rear brake pipes had been in a nasty accident before it got to me so the calipers won't be done this weekend and the driveshaft nut just wouldn't come undone so I changed all the spheres and am sulking. Tomorrow may be easier but today I can't quite raise the enthusiasm!
Vive les UX.
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
Tom what do you need mate? If you need some GSF bits I can get them at discounted price and bring them down with me next weekend dude?
