Digit For Free. *Thread resurrected again. Page 7 this time
- docchevron
You're only jealous Tim!
Right then David, when are we getting stuck into this?
I've got a boot full of Gardner engine at the mo, but that can soon be emptied and filled with tools / beer!
- DavidRutherford
- BX Digit man!
The only answer I can give you is "Not instantly"
I am supposed to be having a major clear out of vehicles at the moment, as I've gone beyond gridlock here. What with suddenly having to accommodate a caravan, what was my sister's BX and another CX I might have just aquired, I do have some space issues.
Give it a week or two, and I might be able to have a sensible answer.
- docchevron
Splendid stuff! No rush on my part mate, I've got a 36foot monster in 2 million bits at the mo anyway, but nod when you wana hand and I'll be there!
Hows the employment prospects looking mate?
Chris G
Chris G
- DavidRutherford
- BX Digit man!
I've dragged this thread up from the depths of time as the question of the DIGIT has arisen again.
Same old problems. Too little space, insufficient time and a Landlord on my case.
Now, I don't really want to get rid of this car, but I have to be just a little bit realistic. If there is someone out there who would be willing to take it on and do some/all of the restoration work, then they are welcome to come and take it away, or I could deliver it.
Failing that, I might even be looking for somewhere to store it for a while, so if there's anyone who knows a friendly farmer with some redundant barn space.....
- docchevron
- DavidRutherford
- BX Digit man!
- docchevron
- DavidRutherford
- BX Digit man!
it doesn't *have* to go, it would just be good to have a move around of stuff here to keep my landlord quiet. If the Digit were to go to someone who could do the restoration that I plan to, then that would be OK, but it's not essential, and it's not what I really want to do.
If I'm honest, I do have too much stuff, and I need to have a clear out... I just don't like getting rid of stuff.
- mat_fenwick
- x 19
- docchevron
- docchevron
Of course they were wrong!
You just never know when you'll need a one or three hundred spare wishbones, TD / valver header tanks and the such. Seems perfectley logical to me!
- DavidRutherford
- BX Digit man!
more pics.
Following on from the "I have corrosion issues" thread, which you can find here, I though I might update the more relevant thread with some photographs.
Here is the Digit in all it's 3-years-off-the-road glory:
Now, this bent rear wing I already knew all about, and was wondering just how to fix:
That is until I discovered this corrosion, which is reasonably serious:
Then looking a bit more, I found more corrosion in the floor:
Sill:
Front scuttle (under the washer bottle.. surprise surprise!):
Fuel filler area (to be fair, this was already quite rotten 3 years ago):
And finally, the bits that will probably mean I have to remove the front subframe:
All this was a bit scary, so I shoved it back in it's hidey hole:
Noticed that it also needs a rear arm bearing, and buggered off to put the kettle on.
Opinions are welcomed. As I say, if it was any other BX it would probably be for the breakers, but I get the horrible feeling that this one ought to be repaired. Not least because it's a non-sunroof model, and I like that.
Sill:
