Robs bx 16 valve phase 2
rob-bx16v
Contact:
Post by rob-bx16v »
Hi There Bazza,
Thanks for your comments. Dont worry about the ffffford lol as i accuired that by accident realy. Now as for the bx i purchased it in june 2001 for £1,200 from a dealer who lived in budleigh salterton and it must have been the tenth or eleventh one i had look at as back then most of them (16v model) were rough. Subject to a 2 hour poke around i bought it cash. Didnt realy want a red one but with a car like this condition was more important than colour. I always say if the bodys sound you can always re-build the mechanics as and when.
The cars engine has been fully re-built using the original block and head but with NEW parts genuine from citroen with the exception of a couple of things ( crank ) The bill from citroen was for around £1,500 for the engine and parts and £ 2,000 for labour and extras i had done (shhhhh) It sounds expensive but at least i know the engine is garenteed and wont blow up due to botched work by someone who doesn know what they are doing like me!. The gear box was taken out and spun on a bench and there was no problems with it so it went back on with a new clutch.
All ancilliries have been renewed over the years, Alternator,starter motor, ign module, coil, water pump, etc. Its had a brand new hp pump, main feed from reservoir to hp pump pipe, Replacement good known working air flow meter from a mates pug 405, Hks cone airfilter modded to fit,
The ECU has been chipped and re-mapped by colins performance in congleton cheshire giving it a smoother power curve and a bit mor go. The rocker cover was taken off and powdercoated red by a local firm for me. Its also fitted with new magnecore performance ht leads and ngk plugs, All engine mount bushes re-newed
Its had a new genuine radiator, all new genuine switches eg water level, oil level, oil temp, fan swicth, new genuine thermostate and cover, Many new coolant pipes, Its had a new steering coupling, various metal hp pipes under the engine at the front. Its got new rear discs and pads recently fitted and EBC turbo groove front discs and ferodo pads fitted front, The brake calipers were cleaned and painted red and all bleed nipples replaced. Lower arms etc were cleaned and painted blue, 17 inch wolf race urban racing alloys fitted with chrome citroen valve caps.
Its had a full straight through custom exhaust fitted (powerflow) The underside was stripped fully de-greased and undersealed (no rust to attack) The rear arms were dismantled and cleaned and painted and fitted with new bearings. A new rear height corrector was fitted, along with new copper fuel pipes, then the whole car was sprayed again underneath with clear waxoyl for the pipes and spray on black wax oyl for all the hard to get to areas and trus me it was absolutly caked in it i also did all of the chassis rails inside by taking the rubber bungs out. Its also been undersealed behind both the front and rear bumpers.
Interior wise i fitted 2 mint fron seats i bought from ebay last year, and fitted a lockwood red dial kit and ripspeed steering wheel and boss as the original steering wheels feel like you are driving a bus. Rear head rests were also fitted (genuine) and i bought a brand new central locking plip from citroen too,
The car is also fitted with a genuine tailblazer, i have had custom number plates made up, fitted an ax gti badge to the rear, clear side repeaters on the wings, The twin head lamps are from cituning ( a citroen tuning firm) and turn up now and again on ebay, The bonnet is a genuine citroen item it is known as a 4 tc but to my knowledge is not a real one but an accessorie from an early citroen catalogue and i shoul imagine they are very rare now??. The fron bumper has been cut out and messhed to allow more airflow, and a chrome numberplate surround fitted.
At the moment ive just got a few things to do to it mechanical wise which are to get the injectors ultrasonicly cleaned, fit my new injector seals and chromed fuel rail, Get an fse powerboost valve and fit, and sort a couple of tyres for the rear.
bx16v p2 k reg red
bx16v p2 j reg green
bx gti 8v h reg blue
escort rs turbo g reg red
rob-bx16v wrote:ive just got a few things to do to it mechanical wise which are to get the injectors ultrasonicly cleaned, fit my new injector seals
Ultrasonic cleaning of my injectors was the most impressive noticeable improvement in engine operation and performance I've ever experienced! :lol: :D 8)
I took mine off the car and down to the local Lucas Centre (even though they're bosch) and as part of the ultrasonic service they fitted new seals and filters. :D
rob-bx16v
Contact:
Post by rob-bx16v »
Thats where they are going ............ Lucas that is. the injectors i have fitted at the mo have now done more than 230,000 miles!
I need to get them done because the next stage is upping the engine power by getting a gas flowed ported camed head.........
bx16v p2 k reg red
rob-bx16v
Contact:
Post by rob-bx16v »
A pic of my brand new plip bought from citroen. I dont put it on my keyring anymore because im sick of breaking the bottom bit. I just carry this with me now and again.
bx16v p2 k reg red
rob-bx16v
Contact:
Post by rob-bx16v »
Bazza wrote:Oh yeah, me Mum and me Sister live in Penzance...... That must make you and me almost cousins.... (so when can I borrow the car?????)
their only 40 mins to an hour down the road. If you come over one day you'l have to come up and see me. Im very very picky about who i let drive my car but being a bx enthusiast you would be ok. Both my mates own audi A4 1.8 turbo quattro,s and they have both been out in the bx and the bx accelerates much faster lol
bx16v p2 k reg red
Jezzie 16v
Post by Jezzie 16v »
Crickey Rob, what do you do for a living to keep two cars so nice?
Nice photo's tho mate :wink:
Jez
89' Bx16v-Leather and Air
89' Bx16 TRS-Lost its will to live
82' Capri 1.6 Caberet- One day I'll drive it
"You have to be trusted, by the people that you lie too"
tim leech
Post by tim leech »
He walks to work Jez?
rob-bx16v
Contact:
Post by rob-bx16v »
:D To be honest the 16v hasent been used in over 2 months. I try not to use it a lot these days and use the gti 8v everyday so currently the 8v is covered in dirt :shock: :lol: . I bought the 16v 7 yeasrs ago on a mileage of 86,000 and its only just done 112,000 now so its been nowhere realy. The rst lives in the garage so the poor bx its kicked out onto the drive :oops:
bx16v p2 k reg red
Jezzie 16v
Jezzie 16v wrote:Crickey Rob, what do you do for a living to keep two cars so nice?
I mean what do you do for a living, if you dont mind me asking?
Jez
rob-bx16v
Contact:
Post by rob-bx16v »
Currently im on incapacaty benefits as i had a breakdown 3 years back through stress and im just about coming out the otherside and looking for a job hence the move from macc to cornwall. 3/4 benefits go on the cars with only 1/4 on living but i do suppliment my money by selling lots on e-bay.
bx16v p2 k reg red
tim leech
Post by tim leech »
Thats what BX ownership does to you Rob. :wink:
Contact:
rob-bx16v wrote: but i do suppliment my money by selling lots on e-bay.
dude, you want to be careful saying that on a public forum..
The gestapo will tax you and take your benefits away if they read that.
rob-bx16v
Contact:
Post by rob-bx16v »
should have made that clearer :o My other hobbie is cb radios and i started collecting at the age of 15 and had at least 45 top models at one point. Im now down to 15 as the rest were sold on ebay to help me finance my 16v repairs and my new rst engine, Didnt want to sell them but otherwise the cars would go nowhere and i would have had to sell one which i didnt want to do........so the radios went instead swings and rounderbouts im afraid :(
bx16v p2 k reg red
Contact:
Ah, now I've been interested in CB for ages, whats the best units to go for mate?
I'm thinking along the lines of installing one in each bus in our preserved fleet and one in the tow truck so we can keep in touch during convey's and rally's etc.
I've been told about mid-block? Although since we wouldn't need a range of more than 10 miles max I guess the old CB unit's would be ok??
rob-bx16v
Contact:
Post by rob-bx16v »
Hi Doc,
Well it all depends on what you want. You could have a straight 40 channel fm cb ie, rotel 220,240 uniden 100,200 etc or you can go for a 40 ch mid band (european band) which is the better band as in the right conditions you can speak not only local but abroad as well. The downside of that is many of us brits prefer to use the uk 27/81 frequencies (40ch fm). I myself im not intrested in that part of things. I use the all mode/all frequency multibanders (converted 10 meter sets for use on cb *illegal* but nobody bothers anymore) I have many QSL cards from around the world and use sets such as the famous president lincoln/jackson/grant or the superstar 3900/cobra 148 gtl-dx. But for what you want i would go for a cobra 29 ltd, maycom em 27, converted rotel etc (these are all 80 channel sets that use the uk and eu bands. Sorry if thats confusing if you need me to make it simpler let me know cheers rob. Ps its still good fun on there (would rather have a cb over a mobile phone anyday).
one of my all-mode sets the President Grant
bx16v p2 k reg red
