Unless you have the special machine for fitting cable ties - and it tightens them very tight - then it will not seal.
Jubilee clips are not expensive.
Try your cable tie and see whet happens - its working with the hose off so it isn't going to do any harm. On a petrol car it could interfere with the mixture - depends on the vent circuit - some loose loads of power (like a Triumph Stag) if the vents leak.
Whats this pipe called please
- MULLEY
- MULLEY
