Not bothered whether it gets moved or not, upto your goodself.
Today, Shaune kindly fitted the rear psgr side curly brake pipe. Had to use some heat & a hamer to free up the rear caliper brake nipple, which eventually came out
Those pesky clamps that hold the pipe in place were akward to get to, so removed the spare wheel & carrier to get a bit more access. Luckily again they did come out with plenty of wd40. By this point the pipe actually snapped where it had been leaking from. Good 2nd hand pipe was fitted.
Another strange anomoly was that we used a very good conditioned different brake nipple from another caliper, & even though it was done up tight it weeped lhm out of it, very strange. So Shaune put the old mangled one back in, copper slipped up so it should come out easily enough if required.
The clonking saga: It appears to eminate from the front height corrector. Not sure why but it does make quite a clonk, Shaune had a fiddle & reduced the amount of clonking that it made, but didn't want to move the height corrector too much incase it caused an issue. I'll post this up on the tech section query anyways.
Very pleased to have a working car back on the road, looking forward to driving her this week to work & back, cheers Shaune
