How do I fix my Tacho? (TZD)
joolie
Post by joolie »
Maybe its been asked a million times before, refer me to a thread if there is one, or explain nice and slow.
running on RME/SVO
Its driven by a sensor on the back of the clutch housing (engine side ) The sensor is a black sylindrical device about 12mm in diameter.
Is the sensor there - and in the correct place like very close to the flywheel (which means just about touching)
Does it still conduct - break the nearest connection and check it for continuity.
