BX Foglight bulbs
My observation on the headlight modification is that the original headlamps are NOT fused. The sidelamps are but they are spread over a number of fuses.
This is for safety reasons - loosing your headlamps suddenly on a dark road is not something to be recommended - and so Citroen in common with most manufacturers deal with the problems of fuses blowing by simply not using any!
What I would do is to use the circuit for each lamp - bit expensive on relays but better than an accident.
Actually thinking briefly about it - I don't think there is any reason why you shouldn't leave the existing wiring in place and simply use the new wiring with the relay in parallel - ie providing a better path and full voltage. No doubt someone will give me a good reason why this will not work/set the car on fire etc.
m_2975
My Cars: 1989 BX 19TRI Estate
1993 BX GTI
1997 Xantia CT Turbo
Post by m_2975 »
I'm going to leave the existing wiring there but put each headlamp on it's own fused supply. Therefore if one blows a fuse, there's still the other there; purely for safety purposes.
The way i'm planning to set it up is to use four relays.
One for the left low beam
One for the left high beam
One for the right low beam
I'm also planning to use expensive, low resistance wire and place the relays in the relay housing just behind the battery.
Don't quite know yet if I should run a separate supply wire for each relay from the battery or run one really thick one and split it.
Still in the planning stages so any suggestions would be great. I'm keen on simplifying the setup so will sleep on it and most likely scrap the above idea! :roll: :roll: :roll: :roll:
My Cars:
'93 BX 19GTi Sedan 5M
'89 BX 19TRI Estate 5M
'89 AX GT(With EFI) 2door 5M
In the Family:
'74 SM IE (Fully Restored) 5M
'90 BX 19TRI122 Sedan 4A
'06 C5 2.2HDi Estate 6A
It gets a tad more complicated if you want to keep the dim dip too.
m_2975
1993 BX GTI
Post by m_2975 »
Australian cars don't have dim dip fitted.
Simple :lol: :lol:
My Cars:
In the Family:
Mike E (uk)
headlamp wiring
Post by Mike E (uk) »
Fair comment on the fuses.
I considered failure modes for a while myself, and decided that if my low beam failed , I would immediately switch to the high beam anyway as a natural reaction.
You could simply omit the fuses as Jeremy suggested, or fit a higher rating fuse as it would be more reliable.
One fuse per headlamp filament after the relay is a nice compromise.
Relays are very reliable too.
I don't think dim dip is worth keeping, modern cars don't appear to have it anyway.
prm
Post by prm »
A drawing of BX wiring mods for headlamps, starter etc, that may help.
http://3.download-3.files-upload.com/10 ... Mods_1.xps
m_2975
1993 BX GTI
Post by m_2975 »
prm wrote:A drawing of BX wiring mods for headlamps, starter etc, that may help.
Thanks but it doesn't seem to work for me???
I'm wondering if I am going to bother with fuses because firstly the originals aren't fused anyway, and secondly there's not a hell of a lot that can go wrong between a battery, relay and a bulb!
My only concern is that in the event (god forbid!) if a collision the headlams wires could short somewhere and possibly cause a fire. It's a remote possibility cause it has EFI and the fuel is well protected but it is still possible. What do we think gents?
My Cars:
In the Family:
prm
Post by prm »
It comes up this end, but try this one.
http://1.download-3.files-upload.com/10 ... ds%201.xps
m_2975
1993 BX GTI
Post by m_2975 »
prm wrote:It comes up this end, but try this one.
Hi Prm,
No Joke "Error 404 File Not Found"
My Cars:
In the Family:
prm
Post by prm »
Have another go :oops: :lol:
Let us know if it comes up, I think I forgot th add URL box on the posting box.
m_2975
1993 BX GTI
Post by m_2975 »
Nope....still not working.
My Cars:
In the Family:
