Damnit. They weren't ABS spec hoses. They are now though:
http://www.fastandfurryous.co.uk/BX/bxabs.html
BX Doseur (brake compensator) valve
- BX Digit man!
back to the openning of this post (HYJACKED) if the dozer valve is leaking from inside the car, you can fix it quite simply by fitting a new rubber protector, wich is still avalible and if you dealer tells you differant, then tell him/them to look it up for a XANTIA, you should also ask for the retaining ring so if you damage the old one on prizing it out you wont be stuck
