braided heater hose BX17TZD
tim leech
Post by tim leech »
I put the underseal on most of it doc afte I had patched most of the holes. and yes its pickled, but saveable.
kermit the frog
Post by kermit the frog »
Sorry this topic seams to have morfed into a rust convention.
but to get back on track has anyone got a hose mentioned in my first post.
Regards KERMIT :roll:
Fraid not mate, I cant find any anywhere, although I'm sure I had some...
Rust, however I can help you with, got plenty of that!
Post by ken newbold »
I've looked today, thinking I had one.
What I've got is a braided hose but it's a fairly short one, which I think is the other one from down the back there somewhere. :(
Citroen it is then unfortunately, unless you can buy a cheaper one from somewhere & get it cut to size??
kermit the frog
Thanks everybody for looking
I will have to got to le CITROEN dealer and ask for a discount HA HA HA :!:
Still i have some time to do it i am not putting it back on the road until the new year.
Regards Kermit
admiral51
Post by admiral51 »
i could be wide of the mark here Kermit but here goes............................
if the pipe is not kinked in any particular way to avoid obstacles have you tried somewhere like Hyphose or similar. i know they deal mainly in hydraulic hoses but they are braided to withstand heat and high pressure think they do the hoses upto a max of 2" diamiter
as i have no knowledge of the BX model i guess im firing in the dark but it may be worth a phone call
colin
kermit the frog
Thanks for that thought don't know why i didn't think of that myself i used to do hydraulics in an earlier job DOH!.
Quite usefull when working on a BX the system was very well designed pity its not still used i am sure with modern materials it would be fantastic but expensive to produce.
I will try that option
Thank's :)
kermit the frog
Thank's :)
