Talking B____X
Re: Talking B____X
Gawd, still no BX likely in the near future... but the 806 is doing OK. Wintery temps finally did fot the battery it came with, so had to buy a new one. Saved about £18 thanks to my eldest's Halfords discount, and with 640 amps it's to to the job. And then some. Found the old one was about 500A... A lot less than recommended. Would a BX TZD benefit from a heavy-duty amp battery. My guess it would... So make sure your BX is fitted with a battery well up to the job
Re: Talking B____X
Well it would seem there is the chance I'll be "with Citroen" earlier than I expected... Watch this space
- x 16
Re: Talking B____X
Good news! Will it be a replacement for the 806, or more of an indulgence?
Re: Talking B____X
Indulgence with a capital 'G' hopefully...
Re: Talking B____X
Actually IT HAS BEEN DECIDED
Indulgence with a capital 'B'
(But in time - seeing as we've just bought a new iMac and a fridge freezer is on the cards... why does real life always ge tin the way?!)
Re: Talking B____X
Operation Green Hornet II is underway....
Re: Talking B____X
The plan is to rescue a stranded BX estate - stranded thanks to a broken clutch pedal. And get it back into a driveable state. Thursday's the day. Updates later on.
1985 CITROEN BX 19GT C1TBX
Re: Talking B____X
Said BX was at CXM....
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
Re: Talking B____X
Well, the problem with trying to rush things means I've hit a snag on timing. As it can't wait until the end of the month I've hit a major snag. With the best of intentions it seems I've once again raised my hopes - and those of others - only to dash them again a few hours later. It is a worrying trend. Maybe I should just **** off and leave it to others to rescue old Citroens
Re: Talking B____X
The end of the month is only 15 days away Phil. Surely that aint a problem to the seller?
If it is, ile give him 100 quid for it and hire a trailer to go get it.
Re: Talking B____X
The issue runs deeper than pure timing, unfortunately. It's to do with appropriate distribution of limited resources... In other words, my lovely wife of 25 years has pointed out (quite rightly) that I have much, much more important commitments especially with our daughter starting at university etc. etc. a very disappointed Phil here, but hey... My family must come first.
Re: Talking B____X
As an update to Phils unfortunate timing reference above.............
Some good news is we are off to see this tomorrow evening and hopefully bring it into the fold of BX's currently being given sheltered accomodation here.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- x 16
Re: Talking B____X
Careful, otherwise you'll turn into Richard the Second
Re: Talking B____X
Excellent!
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
