Mat's BX Blog
Looks like a great place to be and a good way to be there. I was looking for an archtop a little while ago but the enthusiasm has waned somewhat and replaced by other interests - though I can't describe the current project - wall building and privet planting as particularly interesting.
2002 C5 HDi SX estate
- x 16
Ooooh, I don't know Brian - there are probably enthusiast forums for those things too!electrokid wrote:I can't describe the current project - wall building and privet planting as particularly interesting.
This weekend has been mainly spent welding the Discovery. I knew it needed a 'couple of patches' in the front footwells/inner wings but the true extent was only revealed when I took the outer wings off….
Fortunately I had a large amount of galvanised sheet in stock, along with plenty of wire and welding gas. However my mood was not improved when the welder decided to fail after only two patches. We have one local(ish!) hire shop but they don't hire welders. After a lot of searching around I found one a mere 40 miles away which I duely went and collected.
Many burns/cuts and a coat of paint later!
Still need to put it all back together as I'm venturing over to Norwich tomorrow.
It's always worse than it initially looks, youve done a lovely job there mind.
How's the boot floor/ rear x member on this one?
- x 16
Thanks. It sunk in a while ago how much easier it all is if you go right back to shiny metal rather than grind back surface rust. My home made box section won't win any prizes, but is nicely galvanised and strong! I painted it with Zinga and have sealed all the welds; tonight's task is to spray with black waxoyl (I find this reasonably abrasion resistant but doesn't let rust eat away hidden underneath like underseal can) and replace the wings/carpet/trim etc.
The rear cross member is excellent, no rust in any of the seams and boot floor area is still solid but rust has got inbetween the layers of metal. As a slow down tactic I've wire brushed as much as I can away, treated it with phosphoric acid and then filled the seam with waxoyl.
That's so very true. (Just as it is true that it will be a lot nicer in the morning after the night before, if you skip that last drink or two. And as easy to remember when the heat is on.)mat_fenwick wrote:Thanks. It sunk in a while ago how much easier it all is if you go right back to shiny metal rather than grind back surface rust.
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
- x 16
Don't you mean 'institutions'Ooooh, I don't know Brian - there are probably enthusiast forums for those things too!
](./images/smilies/eusa_wall.gif)
Which is why I'm not taking the wings off the Grannybut the true extent was only revealed when I took the outer wings off
Excellent job there Mat
- x 16
Something I'm very excited about - the BX will hit the road at the beginning of next month! Really looking forwards to driving it again, despite driving the 205 daily - it's just too frantic for me to relax whilst driving it, fun though it can be. (At least I know there are unlikely to be any sudden failures waiting for the new owner, I've done close to 1000 miles in the last month and it has all worked 100%).
1985 CITROEN BX 19GT C1TBX
2003 ROVER 25 1.6 iXL AW03EEA
2005 MG ZTT CDTi PLUS + - x 114
I thoughth discoveries were made out of that bermabrite aluminium stuff? or is that just the other panels?
ta!
ta!
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- x 16
All the outer panels are aluminium (apart from the roof), but the structure underneath is still steel. Which can rust badly whilst hidden...
Just had the insurance renewal through for the BX - it's gone up from £230 to £380!!! Bearing in mind this is with the same company, I have an extra year's NCB and no other circumstances have changed I'm rather surprised.
- x 16
Seems to be a common theme, I've done some shopping around and so far the best alternative I've had is £521. I'm going to check whether reducing the cover to third party only knocks it down a bit - in the past that's been more expensive, presumably as less companies offered it. Got to be worth a try though...
- x 16
Will do - I wonder if they do modified cars though? When I put in the 1.9 engine Adrian Flux asked me the difference in bhp - as it was only an extra 2 bhp it made little difference to the price, but now it seems to be restricting my choice drastically. It also rules out most of the price comparison sites, and means I have to spend time on the phone.
On another subject, a few weeks back I spotted a few flash cars on my way back from work. Turns out they were for a magazine!
Yes this is common theme this year, apparently a contributory factor was aired by Jack Straw to the media yesterday and is the fact the insurance companies are now selling our personal information to Ambulance chasing compensation companies which is increasing the number of personal injury claims after accidents...an top insurance insider described it to Jack Straw as the insurance industries ''Dirty secret''. Barmy!mat_fenwick wrote: Just had the insurance renewal through for the BX - it's gone up from £230 to £380!!! Bearing in mind this is with the same company, I have an extra year's NCB and no other circumstances have changed I'm rather surprised.
My insurance on my dive bus doubled with the same company from £380 to £720, when I rang for an explanation stating I was the same person they had insured last year with 1 years less no claims then they were not interested. They actually did me a favour as I rang another company for a quote and when they asked if the vehicle had been modified I told them I had removed all the rear seats and converted it into a camper / dive bus. They then explained I needed specialist camper van / leisure conversion insurance which they would be happy to quote for; I gripped my teeth for a minute waiting for the shock only to be very pleasantly suprised when she came back with £180 for the year including cover for £1000 worth of camping extras..Happy Days
