Posts: 3940 Joined: Sun Dec 04, 2005 2:25 pm
Post
by Dollywobbler » Sun Jan 22, 2012 8:24 pm
No worries. Not sure what to do next. Do I try a new primer head or do I assume the problem lies down the back of the engine? I'd really like to have it usable for a Midlands road trip at the end of the month.
Posts: 7329 Joined: Tue Sep 20, 2005 4:08 pm
x 21
Post
by mat_fenwick » Sat Jan 28, 2012 10:02 pm
If you can bring it round one evening we can have a play, if it's not too late now that is?
Got the new windscreen in now - picture is a bit blurry but you get the idea.
Next job is a gearbox swap and work on the front suspension (assuming life doesn't get in the way!)
Post
by Dollywobbler » Sat Jan 28, 2012 10:13 pm
Thanks Mat. Think it's a bit late now. That said, the Maverick appears to have non-working rear brakes, so the fall-back position is looking a bit ropey!
I did take the BX for a run today. Usual starting horrificness and still down on power (mind you, it's felt like that since I first got it back on the road) but it didn't seem to misfire even when hillclimbing. Maybe I should risk it...
x 21
Post
by mat_fenwick » Sat Jan 28, 2012 10:35 pm
You need to update your signature! There's less to fail suddenly and catastrophically on a diesel engine, so I'd be inclined to give it a go. Good luck!
Post
by Dollywobbler » Sun Jan 29, 2012 10:27 am
I'm minded to agree Mat! Better something slow with good brakes than something quicker with iffy brakes...
Might need to change the 'stat though. Heater output is woeful at the moment.
x 21
Post
by mat_fenwick » Sun Jan 29, 2012 1:04 pm
If you fit the new doors before the return trip, that should help with the cabin temperature!
Post
by Dollywobbler » Sun Jan 29, 2012 1:13 pm
Indeed so! The test drive just was quite chilly with the amount of air blowing in everywhere. I may try and improve the situation before departure...
x 21
Post
by mat_fenwick » Fri Feb 03, 2012 11:18 am
Here's a couple of photos on the way to work this morning.
And glad of a good heater in the BX!
saintjamesy89
Posts: 2012 Joined: Tue May 04, 2010 8:01 pm
My Cars: 1985 Citroen BX19 GT 198x Citroen BX16 TRS auto 1988 Volvo 740 2.0 GL Hearse 1991 Saab 900 16v convertible 2007 Lexus RX 400h SE
x 138
Post
by saintjamesy89 » Fri Feb 03, 2012 12:11 pm
Is that a standard digital display watsit? Looks quite modern for an 80s/90s cit.
2006 Lexus RX 400h SE hybrid
x 21
Post
by mat_fenwick » Fri Feb 03, 2012 12:25 pm
No, it's just a cheap in/out thermometer from eBay, which fitted quite neatly in the space where the clock was on the BX.
Posts: 15625 Joined: Tue Apr 15, 2008 11:12 am
x 174
Post
by Tim Leech » Fri Feb 03, 2012 12:28 pm
mat_fenwick wrote: No, it's just a cheap in/out thermometer from eBay, which fitted quite neatly in the space where the clock was on the BX.
Do you have a link?
x 21
Post
by mat_fenwick » Fri Feb 03, 2012 1:19 pm
Posts: 3209 Joined: Wed Apr 01, 2009 10:38 pm
Post
by Mickey taker » Fri Feb 03, 2012 3:18 pm
if only the back light was green
x 21
Post
by mat_fenwick » Fri Feb 03, 2012 3:50 pm
Shouldn't be a big job to swap the LED for a green one, I agree that blue looks out of place.
JayW
Posts: 1590 Joined: Thu Dec 07, 2006 6:40 pm
x 13
Post
by JayW » Fri Feb 03, 2012 3:57 pm
Bargain! Just bought 2!
