TD Water pump and coolant liquid?
I got the pump off ebay and I didn't have the time to send it back and wait for the correct one to arrive. Of course I had to cut the plastic cover a wee bit but now it fits. If I ever go to the scrapyards I might get new covers for the next pump which will hopefully be the right one, but for now there's no harm done using this one...
Carl
1989 16 Valve
Parts needed:
- One black leather headrest.
1989 16 Valve
Parts needed:
- mnde
- Meteor Man
Dear TB2,Way2go wrote:Never seen one of the pictured radiator 'dipsticks' in any of my GTi Petrols either. Suspect it must relate to Mk1 radiators.jeremy wrote:No dipstick on a TD COOLING system.
I don't see a 'coolant dipstick' in the diagram
If you're referring to the thing in the centre of the diagram, then yes that is the oil dipstick, with the breather hose running off towards the airbox. Nothing to do with the cooling system. Note that the coolant hoses are drawn with thick black shaded lines. The dipstick is only on the diagram for reference as it represents an aerial view of the engine bay with the rad at the front and the heater matrix at the back.
Regards,
Mark.
Hi mark,
it's not an issue anymore. I never thought that the oil dipstick would be used to measure how much coolant was in the system. I was just being paranoid because I hadn't heard the engine for a long time and was very skeptical about it's sound etc.
Everything is fine, I think. The thing confusing me were those two pipes, one going from the oil filler tube to the intercooler, and then from there one going to the air filter on the right. Both pipes are on the diagram from the cooling system, as is the oil dipstick and filler tube. That really confused me, and I don't know what these pipes are good for, I mean the ones on the picture...
Thanks for the input,
Carl
Carl
Carl
1989 16 Valve
Parts needed:
1989 16 Valve
Parts needed:
