You can get this hesitancy at 2 to 3000 revs on a light throttle if the ignition is retarded or the vacuum advance is not working.
Easy to test the vacuum module by simply sucking on the tube to the distributor.
A hesitant 16
- Sir Jim of the Databases
Activa territoryRoger Porter wrote: works out at 29mpg
Good job petrol is a tad or so cheaper than it was a while back!
Jim
