Dipping
- x 25
Dipping
What causes that characteristic dipping (and corresponding rise once the brakes are off) of the tail when stationery at lights?
- Our Trim Guru
Ian_Fearn
All the auto's we've had do it Phil. Never had a manual box BX do it.
My answer on a postcard
is that keeping the car still when in drive requires quite a bit of braking force. This produces a higher than normal pressure within the hydraulic system so that when you release the brakes the pressure then drops rapidly causing the back end to sink.
Over and out from me
Aerodynamica
