Ahhhhh.......the "Slaughtered Lamb" pub!!!American Werewolf?
"Remember..........stay on the paaaaaath!"
35mm, although a (much more common) 36mm 6-sided socket will do.toddao wrote:Also, what size is the driveshaft nut
What you will need is a ball-joint splitter to get the bottom ball-joint taper apart. You'll need the bigger scissor type one rather than a small direct acting one.toddao wrote:do I need a ball joint puller or is there an improvisation?
which seals are these? I'm at sea on this one as there's three pictured here or am I in the wrong area? I need to order these from Citroen todayYou will also require 2 litres Total BV oil, and the 2 gearbox diff seals.
A 2ft breaker bar (Halfords Professional) worked for me on the hub nut with half inch drive. If these break Halfords will (they say) replace them without question.ken newbold wrote:Yes you can get them, but if the nut is really tight you're unlikely to shift it with 1/2 drive. They tend to break.
I have to say, I've never bothered changing these, and I've yet to see a significant leak. Yes, they weep a teeny-tiny bit, but not enough to actually drip.RichardW wrote:the seals you want are the two that fit into the diff where the drive shafts go in. If you don't change them, then they will leak. Guaranteed!
